Rebuiding Inside-out |
bkrantz |
Jun 29 2021, 07:06 PM
914 Guru Group: Members Posts: 8,065 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Back to engine work today. I tried to mount the #3 cylinder, and found interference between the engine stand yoke and a cooling fin.
Attached thumbnail(s) |
bkrantz |
Jun 29 2021, 07:07 PM
More importantly, I realized that the yoke blocks access of the piston pin for #3.
bkrantz |
Jun 29 2021, 07:09 PM
How to get the engine off the stand so I can work on the yoke? Without getting out my hoist, I built up a support from miscellaneous stuff.
bkrantz |
Jun 29 2021, 07:10 PM
Engine off. BTW, I did screw together the various bits of lumber.
bkrantz |
After some grinding.
bkrantz |
Jun 29 2021, 07:11 PM
It works.
Yes, I do realize I could shift the yoke to the other half of the case and not have clearance problems, but that would be too easy. Attached thumbnail(s) |
bkrantz |
Jun 29 2021, 07:15 PM
That let me mount P&C #3 and #4. I did notice that the cylinder on #3 seemed to rock a bit against the case. And after I did a quick deck height measurement, #4 was about .02 inch more than all the others.
bkrantz |
Jun 29 2021, 07:20 PM
I pulled #3 and #4 off, and found small raised edges around the outside of the machined surfaces of the case cylinder holes. The new cylinders seem to be a bit wider and are sitting on the edges instead of square on the machined circles.
I did not want to do any grinding or sanding, and so got out a sharp utility blade and trimmed the raised edges where they might interfere. That made the #3 cylinder sit square without rocking. I still need to work on the #4 seat. Attached thumbnail(s) |
bbrock |
Jun 29 2021, 07:26 PM
This arrived today, from Mario at the Dub Shop: complete EFI and ignition system. A very interesting thread just got REALLY interesting. I'm pretty sure my car is destined for this treatment so will be watching with great interest! (IMG:style_emoticons/default/popcorn[1].gif) |
Morph914 |
Jun 30 2021, 04:43 AM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
Nice work as always! Very interested in the EFI set up. If I can’t figure out my electrical gremlins, I may be going that route.
bkrantz |
Jun 30 2021, 07:07 PM
I know that getting the Dub Shop kit installed and tuned will take some work, but I decided that would be more fun, and give me better results, that fighting with the D-jet system.
bkrantz |
Jun 30 2021, 07:20 PM
I took care of the raised edge on the #4 opening, so the cylinder sits flat. And then I did a quick measurement of deck height, using my caliper with a T-bar attachment. My initial measurements:
#1, .068" #2, .067" #3, .067" #4, .072" These are a bit bigger than I want, and #4 is still trying to cause trouble. I need to set up and measure more carefully, and then see. |
bkrantz |
Jun 30 2021, 07:54 PM
I got my cowl braces back from the paint shop.
bkrantz |
Jun 30 2021, 07:55 PM
I pulled the gas tank out again, and installed the right side brace.
bkrantz |
Jun 30 2021, 07:56 PM
And the left side brace.
bkrantz |
Jun 30 2021, 07:58 PM
Then I got out the frunk hinges. One of these was also at the paint shop.
bkrantz |
Jun 30 2021, 08:00 PM
I installed those with new pivot bolts, and a bit of grease. This photo shows the repair above the hinge I had to make since the PO let the original hinges get bent and open up into the cowl.
bkrantz |
Jun 30 2021, 08:02 PM
Then I got out the frunk lid springs.
bkrantz |
Jun 30 2021, 08:04 PM
Here's my version of using a pry bar against the strut top bushing to pull the spring into place. I put the spring into the second notch for now.
bkrantz |
Jun 30 2021, 08:06 PM
Both hinges ready for the frunk lid, once I get the gas tank installed for real.
Lo-Fi Version | Time is now: 26th September 2024 - 09:05 PM |
