factory oil temp gauge range |
jmitro |
Nov 18 2019, 07:39 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
at what temperature F should the factory 60mm temp gauge start registering?
Using a thermometer, I inserted the factory 200 degree temp sender into boiling water, but the temp gauge did not rise. I know it has power and is grounded because the needle moves when power is applied, but the gauge otherwise does not rise. at 200 degrees F, should the factory gauge show movement? |
Ferg |
Nov 18 2019, 08:57 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Short easy answer is yes. At 200 I would expect the needle to point at the E on the word Temp.
jcd914 |
Nov 18 2019, 10:26 PM
Did you have a good ground connection to the temp sensor?
I have had some trouble in the past grounding sensors while heating them up to test them. I usually use a chunk of copper household wire and twist it around the sensor threads and then clip my test lead to the copper wire.. Jim |
jmitro |
Nov 19 2019, 07:26 AM
no, i didn't ground the temp sender.
maybe that was my problem.... thanks for the tip. I'll give it a try |
VaccaRabite |
Nov 19 2019, 01:05 PM
En Garde! Group: Admin Posts: 13,407 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
jmitro |
Nov 19 2019, 10:26 PM
electric circuitry is not my strongest area...LOL
DaveO90s4 |
Nov 20 2019, 12:06 PM
Member Group: Members Posts: 149 Joined: 26-April 16 From: Australia Member No.: 19,935 Region Association: None |
And when 'plunging' the sender into hot water do not allow both the sender signal wire and the -ve earth / ground wire to touch the water - or you will get a false reading.
Lo-Fi Version | Time is now: 29th March 2024 - 09:14 AM |
