WTB horn pair for 75 914 |
Jett |
Nov 18 2019, 07:49 PM
Senior Member Group: Members Posts: 1,630 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
We have one horn but the other is dead. We cannot tell the HZ of the existing horn, so we would like to buy a matching pair.
Thanks! |
bdstone914 |
Nov 18 2019, 11:19 PM
bdstone914 Group: Members Posts: 4,508 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
We have one horn but the other is dead. We cannot tell the HZ of the existing horn, so we would like to buy a matching pair. Thanks! I have a small bucket of tested horns. Half were dead. I have heard they can be repaired but I have not tried it. The HZ is usually heat stamped into the plastic base. 300 and 335 hz is I remember correctly. Not sure it makes a big deal. I think some late cars only had one horn. The earliest horns has screw on front covers. |
Jett |
Nov 19 2019, 12:35 AM
We have one horn but the other is dead. We cannot tell the HZ of the existing horn, so we would like to buy a matching pair. Thanks! I have a small bucket of tested horns. Half were dead. I have heard they can be repaired but I have not tried it. The HZ is usually heat stamped into the plastic base. 300 and 335 hz is I remember correctly. Not sure it makes a big deal. I think some late cars only had one horn. The earliest horns has screw on front covers. Thanks Bruce, I am not sure if the horn is stock because it is all metal, but manufactured by Hella. I’ll add a picture tomorrow |
914Sixer |
Nov 19 2019, 05:59 AM
914 Guru Group: Members Posts: 8,863 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Look on Ebay. All the Hella stuff is made in India. Since they are under the front pan, marking will be out of sign. No German horns in years.
Jett |
Nov 19 2019, 09:37 AM
Look on Ebay. All the Hella stuff is made in India. Since they are under the front pan, marking will be out of sign. No German horns in years. Nothing viable on eBay (IMG:style_emoticons/default/sad.gif) I am getting a lot of Spam (IMG:style_emoticons/default/smile.gif) |
914werke |
Nov 19 2019, 09:48 AM
"I got blisters on me fingers" Group: Members Posts: 9,995 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
We have one horn but the other is dead. We cannot tell the HZ of the existing horn, so we would like to buy a matching pair. Thanks! I have a small bucket of tested horns. Half were dead. I have heard they can be repaired but I have not tried it. The HZ is usually heat stamped into the plastic base. 300 and 335 hz is I remember correctly. Not sure it makes a big deal. I think some late cars only had one horn. The earliest horns has screw on front covers. (IMG:style_emoticons/default/agree.gif) I as well have a fair sized box of horns. 3 types Ive found on the cars over the years. The combination of the differing Hz horns make up the LOUD noise desired. On the back is a nut that is usually covered in potting material that is used to "tune" the horn to a specific frequency Either 335 or 400. So if you can only find the same (working) HZ horn as you have, you can adjust it. Attached image(s) |
Jett |
Nov 19 2019, 09:53 AM
We have one horn but the other is dead. We cannot tell the HZ of the existing horn, so we would like to buy a matching pair. Thanks! I have a small bucket of tested horns. Half were dead. I have heard they can be repaired but I have not tried it. The HZ is usually heat stamped into the plastic base. 300 and 335 hz is I remember correctly. Not sure it makes a big deal. I think some late cars only had one horn. The earliest horns has screw on front covers. (IMG:style_emoticons/default/agree.gif) I as well have a fair sized box of horns. 3 types Ive found on the cars over the years. The combination of the differing Hz horns make up the LOUD noise desired. On the back is a nut that is usually covered in potting material that is used to "tune" the horn to a specific frequency Either 335 or 400. So if you can only find the same (working) HZ horn as you have, you can adjust it. Rich, the horns on the car appear after market and one is inoperable. Can I buy a working set from you? (IMG:style_emoticons/default/smile.gif) I am getting use to visiting your house (IMG:style_emoticons/default/smile.gif) |
johnhora |
Nov 19 2019, 11:12 AM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
GaroldShaffer |
Nov 19 2019, 02:35 PM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
We have one horn but the other is dead. We cannot tell the HZ of the existing horn, so we would like to buy a matching pair. Thanks! I have a small bucket of tested horns. Half were dead. I have heard they can be repaired but I have not tried it. The HZ is usually heat stamped into the plastic base. 300 and 335 hz is I remember correctly. Not sure it makes a big deal. I think some late cars only had one horn. The earliest horns has screw on front covers. (IMG:style_emoticons/default/agree.gif) I as well have a fair sized box of horns. 3 types Ive found on the cars over the years. The combination of the differing Hz horns make up the LOUD noise desired. On the back is a nut that is usually covered in potting material that is used to "tune" the horn to a specific frequency Either 335 or 400. So if you can only find the same (working) HZ horn as you have, you can adjust it. Those are 70-74 style horns. The 75-76 style mount under the front pan have "horn" that faces forward like these. Not saying the older style won't work, but if you are going for original look then those are not correct. Attached image(s) |
914werke |
Nov 19 2019, 02:38 PM
That's interesting. Ive never seen horns such as those fitted to any 914
GaroldShaffer |
Nov 19 2019, 02:52 PM
That's interesting. Ive never seen horns such as those fitted to any 914 only 75-76. Because of the big bumpers and the way they are mounted to the 75-76 cars there is no room for the horns. The older style horns will direct the sound downward hence the difference in the 75-76 style facing the sound forward. Again not saying the older style work, a horn is a horn. |
drem914 |
Nov 19 2019, 03:39 PM
Senior Member Group: Members Posts: 1,026 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
That's interesting. Ive never seen horns such as those fitted to any 914 My '75 did not have directional horns like that and by all accounts everything was stock on my car before I got it in '84. the one on mine look like the round ones in the first pic posted. |
raynekat |
Nov 19 2019, 04:44 PM
Advanced Member Group: Members Posts: 2,153 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
914LIVE |
Nov 19 2019, 04:50 PM
Newbie Group: Members Posts: 10 Joined: 29-June 10 From: Portland, Oregon. Member No.: 11,890 Region Association: None |
I have owned 10 Porsches (circa '75 & '76) and have NEVER seen the "point forward" HORNS on any of them. As a matter of fact, I have never seen a "point forward" HORN in my life, period. Just saying !!! ================================================ |
raynekat |
Nov 19 2019, 05:02 PM
These point down or to the side....you choose.
racingredsc |
Nov 19 2019, 05:24 PM
Newbie Group: Members Posts: 18 Joined: 12-April 13 From: Columbia,SC Member No.: 15,762 Region Association: South East States |
GaroldShaffer |
Nov 19 2019, 06:07 PM
[quote name='914LIVE' date='Nov 19 2019, 04:50 PM' post='2763423']
================================================ I have owned 10 Porsches (circa '75 & '76) and have NEVER seen the "point forward" HORNS on any of them. As a matter of fact, I have never seen a "point forward" HORN in my life, period. Just saying !!! ================================================ [/quote] [/quote] Fair enough, but every and I mean every 75 /76 I have parted (18 of them) had the exact same style horn as I posted. Maybe they were all replaced at one time (IMG:style_emoticons/default/confused24.gif) but all were mounted under the car, not behind the bumper. |
raynekat |
Nov 19 2019, 06:48 PM
Jett |
Nov 20 2019, 12:09 AM
Jett |
Nov 20 2019, 09:02 AM
We have one horn but the other is dead. We cannot tell the HZ of the existing horn, so we would like to buy a matching pair. Thanks! I have a small bucket of tested horns. Half were dead. I have heard they can be repaired but I have not tried it. The HZ is usually heat stamped into the plastic base. 300 and 335 hz is I remember correctly. Not sure it makes a big deal. I think some late cars only had one horn. The earliest horns has screw on front covers. (IMG:style_emoticons/default/agree.gif) I as well have a fair sized box of horns. 3 types Ive found on the cars over the years. The combination of the differing Hz horns make up the LOUD noise desired. On the back is a nut that is usually covered in potting material that is used to "tune" the horn to a specific frequency Either 335 or 400. So if you can only find the same (working) HZ horn as you have, you can adjust it. Those are 70-74 style horns. The 75-76 style mount under the front pan have "horn" that faces forward like these. Not saying the older style won't work, but if you are going for original look then those are not correct. Do you have a set for sale? |
Lo-Fi Version | Time is now: 19th April 2024 - 05:15 PM |
