Weltmeister 19mm front sway bar bushings, ...anyone got a source? |
naro914 |
Jan 17 2020, 09:48 AM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
A friend of mine is looking for the bushings for where the bar goes through the body for a 19mm Weltmeister sway bar. Any idea where to get these?
dr914@autoatlanta.com |
Jan 17 2020, 09:53 AM
914 Guru Group: Members Posts: 7,772 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Mikey914 |
Jan 17 2020, 10:21 AM
The rubber man Group: Members Posts: 12,622 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Is this the one you want?
https://900designs-container.zoeysite.com/f...-body-bushing-1 We also have the drop link ones too Attached thumbnail(s) |
naro914 |
Jan 17 2020, 11:25 AM
Is this the one you want? https://900designs-container.zoeysite.com/f...-body-bushing-1 We also have the drop link ones too Kinda...but I think that's OEM. Welmeister doesn't have the 'lip' on it. See this thread - part S http://www.914world.com/bbs2/index.php?showtopic=327883 |
914werke |
Jan 17 2020, 12:06 PM
"I got blisters on me fingers" Group: Members Posts: 9,894 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Luke M |
Jan 17 2020, 05:35 PM
Senior Member Group: Members Posts: 1,366 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
I know that I have a few new sets. I'll post some pics after I locate them.
Maybe Mark can reproduce them?? |
jim_hoyland |
Jan 17 2020, 09:12 PM
Get that VIN ? Group: Members Posts: 9,225 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Literati914 |
Jan 17 2020, 10:31 PM
Senior Member Group: Members Posts: 1,396 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I have a 19mm bar too, could probably use new bushings as well.
jim_hoyland |
Jan 18 2020, 08:17 AM
sixnotfour |
Jan 18 2020, 08:57 AM
914 Wizard Group: Members Posts: 10,392 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
(IMG:style_emoticons/default/beerchug.gif) they are really simple to make ..simple lathe job
https://www.rosepassion.com/en/parts-porsch...mm-1309-0-87650 Attached image(s) |
Luke M |
Jan 18 2020, 09:00 AM
I found my welt sway bar and bushings. The one I have is a 22 mm but the bushings look the same as a 19 mm. I believe my brother has the 19 mm one for his 914.
Anyways, I have two different type of bushings. One set is for the welt bushing cups and another set for the factory cups. These should be pretty easy for 914rubber to knock out. Both bushing sets are made from a hard plastic. See pics. Attached image(s) |
mskala |
Oct 22 2023, 03:48 PM
R Group: Members Posts: 1,923 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
I just did some bushing work on my old 19mm Weltmeister front bar.
The bushings are not quite the same as the ones shown for 22mm. I made new out of delrin, which is probably not the best material for this but the huge bearing surface should make it okay for most uses. The dimensions you need are 1.505" long, 1.128" OD, 0.752" ID. No lip on either end, the piece bolted to the fender well has a stop on the inside. As others have said, there is some room for the bar to move sideways, so be prepared after pushing the arm as far as it will go, to have a small spacer to fit in-between the bushing and arm. |
Shivers |
Oct 22 2023, 06:01 PM
Senior Member Group: Members Posts: 2,292 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I just did some bushing work on my old 19mm Weltmeister front bar. The bushings are not quite the same as the ones shown for 22mm. I made new out of delrin, which is probably not the best material for this but the huge bearing surface should make it okay for most uses. The dimensions you need are 1.505" long, 1.128" OD, 0.752" ID. No lip on either end, the piece bolted to the fender well has a stop on the inside. As others have said, there is some room for the bar to move sideways, so be prepared after pushing the arm as far as it will go, to have a small spacer to fit in-between the bushing and arm. “As a bushing material, delrin boasts many important properties including high tensile strength, high impact strength, high elongation, high chemical resistance, low moisture absorption, and more. In addition to low deflection, delrin's best feature when compared with polyurethane is self-lubrication.” https://ridetech.com/why-you-need-delrin-th...f%2Dlubrication. |
Lo-Fi Version | Time is now: 28th March 2024 - 03:12 PM |
