Another Fuel Pump Location Thread |
bkrantz |
May 21 2020, 08:56 PM
914 Guru Group: Members Posts: 7,666 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Move the pump (1973 2.0) from the stock location to the front? If so, cut an access hole like later years?
Can somebody please send a photo of the frunk rear wall, taken straight on, so I can get some dimensions for the hole? |
stevegm |
May 21 2020, 08:59 PM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
I’m working on the same problem now too. I’m thinking about locating it under the gas tank. I think that is a common solution. I don’t want to cut the front bulkhead.
(IMG:style_emoticons/default/popcorn[1].gif) |
ndfrigi |
May 21 2020, 09:26 PM
Advanced Member Group: Members Posts: 2,925 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
several members have place it beside the steering column.
This is what I may be doing also. |
yellowporky |
May 22 2020, 12:41 AM
Member Group: Members Posts: 422 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California |
I did a lot of searching for photos too and this is what I concluded to be as correct as possible
Hope this helps |
Tbrown4x4 |
May 22 2020, 03:08 AM
Senior Member Group: Members Posts: 699 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
I put a CB pump up front under the tank, with the filter mounted by the steering rack. DD like this for 3 years without problems. I do want to add the plate and hole to avoid pulling the tank if the pump fails. (You never know.)
I handled my pump wiring with a module from Revolution Electronics. https://www.revolutionelectronics.com/Produ.../Fuel_Pump.html I found it easier to wire the pump from the fuse panel, and I like the 3 second prime and the safety shut off. (No ign signal, no pump.) If the module fails, you short the purple wires together and drive home. |
mlindner |
May 22 2020, 05:10 AM
Senior Member Group: Members Posts: 1,496 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
roblav1 |
May 22 2020, 11:44 AM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
I ran stainless lines, appropriately bent, through the boxed support structure into the tank compartment. Still need to wire it. Pump was recommended by PMO.
Attached thumbnail(s) |
porschetub |
May 22 2020, 03:27 PM
Advanced Member Group: Members Posts: 4,695 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
several members have place it beside the steering column. This is what I may be doing also. (IMG:style_emoticons/default/agree.gif) best location,I'am not a fan of having a fuel pump inside the car but that's just me,the undertray panel keeps the pump out of the weather and offers protection from knocks. |
bkrantz |
May 22 2020, 09:06 PM
Thanks, everyone.
Lo-Fi Version | Time is now: 28th March 2024 - 12:19 PM |
