> Jack receiver or donut mounting point repair first?
Tdskip
post Jul 5 2020, 01:35 PM
So I made the “mistake” of looking more carefully at my problem child blue 914 today. When the DPO tried to repair the hell how damage they put a flat piece of metal where the passenger side rear donut goes.
They also used an incorrect piece of metal where the jacking point goes.
I have good long/jack receiver donor metal as pictured.
So - am I better off replacing the donut area or the jack receive point of the long?
Thanks!
BPic
post Jul 5 2020, 01:51 PM
Thinking on how they fit on the car I don’t think it matters. The donut and triangle fit on the inside of the long seam and the part you have is outside. If you’re using the entire piece and not just a jack point I would probably do that part first just because I like to do the bigger things first.
Tdskip
post Jul 5 2020, 01:54 PM
QUOTE(BPic @ Jul 5 2020, 02:51 PM) *
Thank you for the reply and hope you had a good Fourth of July.
I was leaning towards that section as well because it should make it easier to fit it properly because it has all the factory points on it still making it easier to lineup.
Thanks again for the response.
euro911
post Jul 5 2020, 02:08 PM
A good mod that I do ... enlarge the existing weep hole to allow better drainage and add a second weep hole at the opposite end ...
Tdskip
post Jul 5 2020, 02:30 PM
Great tip Mark, thanks
bkrantz
post Jul 5 2020, 08:53 PM
I did the same mod. Makes it possible to actually flush out dirt.
Tdskip
post Jul 5 2020, 09:09 PM
Thanks for the confirmation.
Ordered the metal repair piece, interestingly these are apparently not support to be used for jacking points according to an earlier thread here.
euro911
post Jul 6 2020, 01:17 AM
QUOTE(Tdskip @ Jul 5 2020, 08:09 PM) *
HUH? (IMG:style_emoticons/default/confused24.gif)
Every VW I've owned (including the 914) uses a similar jacking method ... that's where the stock VW jack fits (IMG:style_emoticons/default/popcorn[1].gif)
Tdskip
post Jul 6 2020, 10:10 AM
QUOTE(euro911 @ Jul 6 2020, 02:17 AM) *
Hi Mark. I'm referencing this thread;
http://www.914world.com/bbs2/index.php?showtopic=344274
- Lo-Fi Version Time is now: 16th April 2024 - 03:45 AM
