FS Pushrod tubes with o-ring sets, 3 sets, $70 per set shipped |
bdstone914 |
Sep 14 2020, 08:43 AM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Edit: several sets still available
I have three sets of the later, larger diameter pushrod tubes that were cleaned and replated. New Viton o rings were installed. Some small dents. Will fit all Type IV except early 1.7L heads with smaller holes with engine number prior to WO 057 461. $70 for the set shipped USPS Priority mail in the U.S. I have more o-rings on order for the sets pictured with out o-rings. Attached thumbnail(s) |
bdstone914 |
Oct 8 2020, 02:59 PM
Bump
mark04usa |
Oct 9 2020, 10:09 PM
'70 1.7 Tangerine Group: Members Posts: 351 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region |
None to fit poor old lonely early 1.7? Hard to find good outter o-rings also. (IMG:style_emoticons/default/unsure.gif)
bdstone914 |
Oct 10 2020, 06:38 AM
None to fit poor old lonely early 1.7? Hard to find good outter o-rings also. (IMG:style_emoticons/default/unsure.gif) Pelican has the o rings. I had one set which i sold. Look up the o ring part number in PET and plug it into the Pelican search. |
mark04usa |
Oct 12 2020, 05:15 PM
None to fit poor old lonely early 1.7? Hard to find good outter o-rings also. (IMG:style_emoticons/default/unsure.gif) Pelican has the o rings. I had one set which i sold. Look up the o ring part number in PET and plug it into the Pelican search. I should clarify...hard to find proper fitting and reliable outboard o-rings for early 1.7 |
bdstone914 |
Oct 12 2020, 06:42 PM
@mark04usa
None to fit poor old lonely early 1.7? Hard to find good outter o-rings also. (IMG:style_emoticons/default/unsure.gif) Pelican has the o rings. I had one set which i sold. Look up the o ring part number in PET and plug it into the Pelican search. I should clarify...hard to find proper fitting and reliable outboard o-rings for early 1.7 As stated before, Pelican has them in muliple brands |
bdstone914 |
Oct 18 2020, 08:51 PM
Bump. Price reduced $10
Lo-Fi Version | Time is now: 23rd April 2024 - 04:20 PM |
