J tube block off cap, for the cars with single heater blowers |
brant |
Sep 15 2020, 10:10 AM
914 Wizard Group: Members Posts: 11,611 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
an original, J-tube cap for the heater system
not cracked, clean condition $6 shipped in the US Attached thumbnail(s) |
Gint |
Sep 15 2020, 10:25 AM
Mike Ginter Group: Admin Posts: 16,066 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I just bought three of those. (IMG:style_emoticons/default/biggrin.gif)
brant |
Sep 15 2020, 10:28 AM
Nice.
does the -6 use them? |
BillC |
Sep 15 2020, 12:07 PM
Senior Member Group: Members Posts: 535 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
I'll take it! PM incoming.
nditiz1 |
Sep 15 2020, 12:32 PM
Senior Member Group: Members Posts: 1,177 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Can you get me the inside and outside diameter? Wondering if this will fit the backdated heat pipe off the fan shroud (drivers side)
Gint |
Sep 15 2020, 02:59 PM
They fit over the J tube that comes up through the engine tin from the heat ex changers. If you don't have a auxiliary electric fan, you use these to cap off the J tubes. So whatever size that J tube is, the inside diameter of the cap needs to fit over, and not necessarily snugly. They are typically fitted with a hose clamp, which is why they have two slots. Getting an accurate inner and outer dimension on a 50 year old plastic cap is a bit of a crap shoot, but...
2.13" inner (54.2 mm) 2.37" outer (60.3 mm) |
Lo-Fi Version | Time is now: 24th April 2024 - 05:00 AM |
