Fuel pump issue, no fuel... help |
steuspeed |
Sep 22 2020, 09:43 PM
Senior Member Group: Members Posts: 1,003 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
What am I missing? Turn the key and I can hear the fuel pump run then stop. Turn key to start and the engine cranks. Broke the lines in the engine bay. Crank the engine and no fuel comes out the hoses. Blocked line between pump and engine bay?
If I spray some start fluid in the air box the engine fires right up. This is my new project car. Just drove it home last week. |
Frankvw |
Sep 23 2020, 01:07 AM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
No fuel at all ...mmm...after pump : maybe clogged up fuelfilter. Could also be fuelpump itself ofcourse.
If there is no fuel on the pumpside (before pumpaction) maybe kinked fuel hose under the tank or the filter in the tank is clogged) |
steuspeed |
Sep 23 2020, 02:15 AM
No fuel at all ...mmm...after pump : maybe clogged up fuelfilter. Could also be fuelpump itself ofcourse. If there is no fuel on the pumpside (before pumpaction) maybe kinked fuel hose under the tank or the filter in the tank is clogged) There is an old filter down by the fuel pump. That is my next move. Does the pump run until it gets pressure? I'm thinking if it's clogged then the pump runs and stops for that. |
falcor75 |
Sep 23 2020, 02:49 AM
Senior Member Group: Members Posts: 1,578 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Dumb question but is there fuel in the tank? Shine a flashlight down the filler neck and look for crud around the in/outlets.
When you turn the key the pump primes for 2-3 seconds, I think its on a timed circuit and not pressure regulated. |
Frankvw |
Sep 23 2020, 02:54 AM
"Does the pump run until it gets pressure?"
No, I think it runs a few cycles and not untill it gets pressure, because it will also do that with an empty tank... |
ClayPerrine |
Sep 23 2020, 03:49 AM
Life's been good to me so far..... Group: Admin Posts: 15,367 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Is the fuel pump wired backwards? It won't make pressure if it is.
I would bet on something clogging the lines. If the car has been sitting a long time, it could be the screen in the tank, or the fuel filter. |
steuspeed |
Sep 23 2020, 10:22 AM
Gauge showed about half tank when I drove it home. Yes, the car sat for 11+ years. I'm going to check the lines under the car at the fuel pump today.
lierofox |
Sep 23 2020, 12:55 PM
Member Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California |
Gauge showed about half tank when I drove it home. Yes, the car sat for 11+ years. I'm going to check the lines under the car at the fuel pump today. Hopefully the tank was prepped before storage, and wasn't full of rust. If it was, particles and chunks might have settled onto the tank strainer or the fuel filter. (That's how my first fuel pump got ruined in my 914 project car.) |
steuspeed |
Sep 24 2020, 10:30 PM
Dumb question but is there fuel in the tank? Shine a flashlight down the filler neck and look for crud around the in/outlets. When you turn the key the pump primes for 2-3 seconds, I think its on a timed circuit and not pressure regulated. Ding ding ding... It was out of gas. It literaly only had fuel in the line and it the old filter. How I made it home is a miracle. It was stumbling the last few blocks. I thought it was vacuum lines since half of them were not connected or wrong. Once I put 1/2 gal of gas in it and got it running, I checked to see what the guage said. Yup, 1/4 tank. Then I tapped on the gauge and it went to zero. Warning light is not working either. Bulb checked out okay. Maybe a half gal won't trip the warning light? |
ndfrigi |
Sep 24 2020, 10:55 PM
Advanced Member Group: Members Posts: 2,925 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Dumb question but is there fuel in the tank? Shine a flashlight down the filler neck and look for crud around the in/outlets. When you turn the key the pump primes for 2-3 seconds, I think its on a timed circuit and not pressure regulated. Ding ding ding... It was out of gas. It literaly only had fuel in the line and it the old filter. How I made it home is a miracle. It was stumbling the last few blocks. I thought it was vacuum linse since half of them were not connected or wrong. Once I put 1/2 gal of gas in it and got it running, I checked to see what the guage said. Yup, 1/4 tank. Then I tapped on the gauge and it went to zero. Warning light is not working either. Bulb checked out okay. Maybe a half gal won't trip the warning light? A few friends 914 had same issue and I told them to add gas and fixed the problem. We can’t just trust our gauges since it is around 45 yrs old already. |
falcor75 |
Sep 26 2020, 04:05 AM
Glad it worked out, sometimes its indeed the simplest things. (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 28th March 2024 - 11:25 PM |
