Weird shift coupler issue |
Tdskip |
Sep 23 2020, 04:08 PM
Advanced Member Group: Members Posts: 3,674 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Well this is a first-the shift coupler won’t fit onto the rod that connects the coupler to the shifter.
Do I need to just wire brush the rod that comes out through the opening in the firewall to make sure that there’s no scale on it? I can’t feel anything hanging it up with my fingers. Anyone ever had this happen to them? |
76-914 |
Sep 23 2020, 04:45 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,455 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
That rod looks like hammered (IMG:style_emoticons/default/stromberg.gif) Try a file to akee down the high spots. Clamp a crescent wrench on it and rotate the wrench to be sure it isn't out of round and to locate the high spots. (IMG:style_emoticons/default/beerchug.gif)
Bleyseng |
Sep 23 2020, 05:34 PM
Yep, clean all those nicks and wacks off so it's smooth and it will go it.
Tdskip |
Sep 23 2020, 09:23 PM
Thank you for the responses, I’ll get it cleaned up in any nicks or ridges filed down. And try again.
It’s always interesting to see the unexpected challenges that these cars throw your way. |
rhodyguy |
Sep 23 2020, 10:06 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,042 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Is that a crack in the coupler bushing on the left?
Tdskip |
Sep 23 2020, 10:12 PM
second wind |
Sep 23 2020, 11:27 PM
Senior Member Group: Members Posts: 847 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Just as an aside....look at the number of posts all you guys have......I am honored to be in your company....I am buying a new to me used Craftsman bench grinder tomorrow morning for little touch ups like this.....hand file and wire wheel and back in business....my rear lug nuts will look respectable again by noon tomorrow.....all the best,
gg |
Mikey914 |
Sep 23 2020, 11:59 PM
The rubber man Group: Members Posts: 12,624 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
A fine file will work nicely too. probably just a burr.
TheCabinetmaker |
Sep 24 2020, 08:56 AM
I drive my car everyday Group: Members Posts: 8,299 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Might want to ditch that worm gear house clamp too, if your car is injected.
Tdskip |
Sep 25 2020, 09:18 AM
Might want to ditch that worm gear house clamp too, if your car is injected. Thanks for all of the responses. @TheCabinetmaker - this is a low pressure Weber build for now just to get it driving but I VERY much appreciate the safety consideration. I’ve started using proper FI clamps on everything ( even cars that are carbureted) when I actually button everything up for good. I’ll get a file on this and report back. Thanks! |
maf914 |
Sep 25 2020, 04:24 PM
Have you changed out the two bushings inside the coupler? Not hard to do. They look a little rough in your photo. I know from experience that when they fail or disintegrate (in my case) the ability to shift will disappear.
Tdskip |
Sep 25 2020, 06:07 PM
Have you changed out the two bushings inside the coupler? Not hard to do. They look a little rough in your photo. I know from experience that when they fail or disintegrate (in my case) the ability to shift will disappear. Hi Mike - agree, and thanks for pointing it out. I have replacement ones, just “roughing” everything in at this point since the car came to me as a roller and the engine/trans are from a different donor. If I decide to keep it it will all be gone through. Thanks again for the eyes on it and smart suggestion. |
IronHillRestorations |
Sep 25 2020, 09:09 PM
I. I. R. C. Group: Members Posts: 6,707 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I've seen rear bars that got bent enough to have trouble fully engaging at the coupler.
Tdskip |
Sep 26 2020, 06:08 AM
I've seen rear bars that got bent enough to have trouble fully engaging at the coupler. Good morning, wow, those must have been pretty bent. I’m planning on connecting the shifter today so I’ll soon find out if I have an issue there. Thanks for the response, hope you are doing well. EDIT - turns out I did have a burr on the end as you all suggested, and once I took the Dremel to it problem solved. Everything is back and connected. Weird that this piece was nicked and generally beat up, maybe the last person working on it had an anger management problem? |
forrestkhaag |
Sep 27 2020, 01:24 PM
I've seen rear bars that got bent enough to have trouble fully engaging at the coupler. Good morning, wow, those must have been pretty bent. I’m planning on connecting the shifter today so I’ll soon find out if I have an issue there. Thanks for the response, hope you are doing well. EDIT - turns out I did have a burr on the end as you all suggested, and once I took the Dremel to it problem solved. Everything is back and connected. Weird that this piece was nicked and generally beat up, maybe the last person working on it had an anger management problem? Pleas let us know how your subsequent linkage adjustment goes..... I remain a three gear guy for now but at 4K, the six is sailing along above most posted speed limits in our small town.... (IMG:style_emoticons/default/confused24.gif) |
Tdskip |
Sep 27 2020, 01:26 PM
I've seen rear bars that got bent enough to have trouble fully engaging at the coupler. Good morning, wow, those must have been pretty bent. I’m planning on connecting the shifter today so I’ll soon find out if I have an issue there. Thanks for the response, hope you are doing well. EDIT - turns out I did have a burr on the end as you all suggested, and once I took the Dremel to it problem solved. Everything is back and connected. Weird that this piece was nicked and generally beat up, maybe the last person working on it had an anger management problem? Pleas let us know how your subsequent linkage adjustment goes..... I remain a three gear guy for now but at 4K, the six is sailing along above most posted speed limits in our small town.... (IMG:style_emoticons/default/confused24.gif) If you are back in SoCal we can get the car on a lift and see what’s going on? Missing R&1 or 4&5? |
ndfrigi |
Sep 27 2020, 02:00 PM
Advanced Member Group: Members Posts: 2,925 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Hi Forrest, it’s been awhile and hope u can visit socal again and join one of the small events or meet ups!
Lo-Fi Version | Time is now: 28th March 2024 - 08:20 PM |
