metalvolks |
I'm new here ... Group: Members Posts: 0 Joined: 7-December 20 From: San Diego, CA Member No.: 24,961 Region Association: Southern California ![]() |
Happy Sunday everyone! Below is a complete list of 914 parts that I have for sale. I have hundreds of photos organized on a webpage with the link below. PM me with what you want and a zip code for shipping! I can ship about anything or meet you here in San Diego county. Parts will be removed from my site once they are paid for. I'm flexible on most prices and can do discounts depending on how much you need. PM me for more details on each part. All parts sold as-is.
(IMG:http://www.914world.com/bbs2/uploads_offsite/paulmichaelrogers.com-24961-1609612351.1.jpg) Parts List: Engines/Engine Mechanical Parts 1975 2.0 GC Case - Good Condition - $400 1973 1.8 EC Case, Crank, Rods, Cam and Oil Pump - Good Condition - $300 1.7 Long Block with heat exchangers (Complete Engine minus carbs, intake, distributor. Unknown Condition, Spins Freely - $600 OEM Oil Cooler - Good Condition - $40 Engine Tin (1/2 Side Tin - 3 1.7/1.8 $40/each, (4 Rear Tin, $40/each), (Misc. Tin, $10-20/each). Condition ranges from fair to good. Thermostat - $50 2.0 Air Cleaner Housing - Surface Rust, but overall good condition - $40 SOLD - OE Oil Pump - 021 115 109A - $30 Oil Filter Mounting Console - $30 SOLD - 2.0 Oil Pickup and Windage - $40 SOLD - 1.7/1.8 Heat Exchangers (smoke tested ok) - Good Condition - Surface Rust and Paint, but solid - $150 1.7/1.8 Heat Exchangers (smoke tested ok) - Fair Condition - Surface Rust - $80 1.7/1.8 Stainless Steel Heat Exchangers (smoke tested ok) - Great Condition - $400 2.0 Heat Exchanger (smoke tested ok) - Passenger Side - Fair Condition - $100 SOLD - 1.8 Heads - Good Condition (No Visible Cracks) - 021 101 371 S - $120 (Set) 2.0 Heads - Bare - 1 Head Great Condition (no cracks), 1 Head Machining Needed (Valve Seat Damage, 1 broken fin and 1 bent fin) - $350 (Pair) Cooling Shroud (Good Condition) - $100 Cooling Shroud w/Alternator - Good Condition (small crack) - $100 Aftermarket Muffler - $75 A/C Compressor (York) Stock (unknown condition) - $40 1.7 (2 sets)/1.8/2.1 Cylinders (90 (2 sets) /92/96mm) - 92mm Cylinders and 96mm Cylinders SOLD, Pistons and Pins (most cylinders in good shape-all need to be honed. A few pistons have gouges and nicks. Pins would need to be polished) - $80 for entire lot Pressure Plates - $20/each SOLD - Flywheel - $40 SOLD - Connecting Rods - $40 Camshafts - $30/each Crankshafts (Don't know for which motor) - $40/each SOLD - Smog Pump - $40 SOLD - Engine Parts Lot1 (rocker arms, lifters, pushrods, springs, gaskets, etc) - $50 Engine Parts Lot2 (motor mounts, etc) - $50 Engine Support Cross Bars - $60 for early style, $100 for later style SOLD - Early 2.0 Muffler Bracket - $20 1.7 & ('74 1.8) Muffler Bracket - $20 Engine Electrical Parts SOLD - Bosch Blue Coil - $20 Heater Blower Motors (TESTED-WORKING)- $80/each Relay Board - $50 Alternator (with Cooling Vent) - $40 Transmission Parts Shift Rod Linkages (3) - $25/each ($0 for broken one) Interior/Mechanical Shifter - $50 Seat Bracket - $40 Interior Passenger Door Pulls - $30/each Driver Door Pocket (Blue) - $20 A-Pillars - Poor to Fair Condition - $20/set Ash Tray - $20 Driver Door Pocket Covers - Fair Condition - $20/each Rear View Mirror - Fair Condition (Glass Issues) - $20 Upper Windshield Trim - Fair Condition - $20 Carpet Sill Trim Lot - $20 Seat Belt Receivers - $25/each Misc. Interior Vents - $20 SOLD - Pedal Board (Decent Condition) - $40 Dash Trim Plate - Very Straight - $20 Center Console Shifter Panel/Trim/Cover & Defrost Switch - $20 Console Box (Fair Condition) - $20 Body/Electrical Tail Lights (2 lefts, 1 right) - Poor to Fair Condition (usable) - $20/each Front Turn Signal Housings - Fair to Good Condition - $20/each Horn - $20 Fresh Air Box and Fans - $100/each Windshield Wiper Motors/Headlight Motors and Windshield Wiper Linkage - $40/each Headlight Assembly Lot - Fair Condition - $60 Fog Light Grill - Poor to Fair Condition (2 Cracks) - $20 A/C Evaporator, Fan and Enclosure DPD - $40 Misc. Relays, Switches, Actuators (Unknown Condition) - $20 Rear License Plate Lights - $20 Body SOLD - 1973 914 Rolling Shell - Mainly surface rust. Hellhole, Rockers, Longs, Floors, Battery Tray, etc. solid. Small hole in floor, battery tray, spare tire well and trunk. Left Rear Shock Tower Needs Replacement. Has suspension, 5 steel "sport wheels", passenger windows and mechanism, etc. - $600 Engine Compartment Covers - $40 (white one is SOLD) SOLD - Engine Compartment Cover (Complete) With Rain Tray (Great Condition-No Dents) (Early Model) - $250 Rain Trays (2) - Both Have Small Cracks (can be fixed easily) - $80/each Targa Top (Good-Usable Condition - w/Front Latches) - $125 SOLD - Targa Top (Good Condition - w/ 1 Front Latch) - $125 SOLD - Front Hood (Great Condition - no dents, light surface rust, latch) - $125 SOLD - Dash Frame (Good Condition) - $80 SOLD - Front Bumper (Chrome Painted Black - Fair Condition) - Fairly straight with only a few dents- $80 Windshield Trim (Poor Condition - Mostly Bent) - $0 License Plate Bracket - $20 Bumper Guards (Good Useable Condition) - $20 SOLD - Rear Valance - poor to fair condition - $20 Spare Tire Well Section - $20 Brakes SOLD - Rear Calipers (Good Condition-Needs Rebuild) - $30/each Rear Backing Plates - Fair Condition - $15/each Front Backing Plates - Good Condition - $20/each Suspension Aftermarket Unknown Brand Springs - Very High Spring Rate it Appears (Pair) - $40 SOLD - Weltmeister SP100 Rear Springs (Pair) - $60 Stock Rear Springs - 3 Red Stripes (2 Pair) - $20/each pair Spring Hats, Seats & Hardware (Lot) - $25 Rebuildable Rear Bilsteins? 2 of them seem to work ok - $20/all Tie Rods - $20/all Front Suspension, uprights, spindles, backing plates, crossmember - $100 Glass: Driver's Window - Good condition - $60 Rear Glass - Good condition - $60 Misc. Fuel Tank - $40 Fuel Tank Bumpers - $10/each Windshield Washer Bottles - $20/each Fuel Expansion Tanks (1 Plastic, 3 Metal) - $20/each Wiper Arms Lot - $20 Charcoal Canister (2) - $20/each Hood Springs and Hinges - $40 Factory Lug Wrench - $20 Thank you for looking! PICTURES ARE HERE! http://paulmichaelrogers.com/porsche914parts/ Paul |
rcarson25 |
Newbie ![]() Group: Members Posts: 49 Joined: 15-May 17 From: TN Member No.: 21,103 Region Association: South East States ![]() ![]() |
I know he is new here at 914world, but I have known Paul for years. He is a good guy and good seller so you can buy with confidence.
914sgofast2 |
Member ![]() ![]() Group: Members Posts: 209 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None ![]() |
PM sent for 1.8L heads, oil pickup & windage teay, oil pump, and passenger door pocket.
frostyf |
Member ![]() ![]() Group: Members Posts: 92 Joined: 27-March 14 From: VA 23455 Member No.: 17,168 Region Association: MidAtlantic Region ![]() ![]() |
Hi Paul, PM'd you about weltmeister SP100 Rear Springs (Pair) - $60
And bilstein shocks. Nick |
porscheaddic |
Member ![]() ![]() Group: Members Posts: 62 Joined: 9-July 07 From: california Member No.: 7,898 ![]() |
Hi Paul,
Sent you a pm regarding the rods, and rear brake calipers. Thanks, Vince |
jdbogart@self-serv.net |
Newbie ![]() Group: Members Posts: 5 Joined: 17-July 19 From: California Member No.: 23,305 Region Association: Southern California ![]() |
Hi Paul -
I'm looking for the D-ring with the short fabric strap that leads to underneath the speaker housing. It would be for a 1970-71 914 removable footrest. Opposite the D-ring on the strap would probably be a hole for a speaker housing screw to go through. Thanks Don |
metalvolks |
metalvolks |
metalvolks |
metalvolks |
I know he is new here at 914world, but I have known Paul for years. He is a good guy and good seller so you can buy with confidence. Thanks Ryan and thanks everyone for the interest in the parts. Please remember to view all the pictures for each part via the link I provided in the ad (I had so many pictures it would have been a nightmare to add them all to 914world). Click on each part and then click on each picture to view a high def picture. Paul |
second wind |
Senior Member ![]() ![]() ![]() Group: Members Posts: 542 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California ![]() ![]() |
Hello Paul.....I would like dibs on the 2.0 stainless steel heat exchanger.....thank you very much.
gg |
metalvolks |
Ampex351 |
Member ![]() ![]() Group: Members Posts: 85 Joined: 8-April 20 From: Roseburg, Oregon Member No.: 24,115 Region Association: Pacific Northwest ![]() |
Paul, I need that antenna off of the white 914 body. Complete with the rubber base.
Thanks, Roger |
metalvolks |
second wind |
[quote name='metalvolks' post='2877018' date='Dec 21 2020, 03:12 PM']
[quote name='second wind' post='2877016' date='Dec 21 2020, 02:58 PM'] |
metalvolks |
Friendly bump (IMG:style_emoticons/default/smile.gif)
metalvolks |
Another Friendly Bump!
Ampex351 |
metalvolks |
930cabman |
Member ![]() ![]() Group: Members Posts: 184 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
Are the rear calipers and backing plates available? If so, I will take them.
thank you |
Lo-Fi Version | Time is now: 23rd January 2021 - 01:18 AM |
