I found a 911 front suspension, now what? newbee question |
Tdskip |
Feb 9 2021, 11:41 AM
Advanced Member Group: Members Posts: 3,697 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
All true - but - sometimes having bigger brakes results in a better pedal feeling or sense of braking power. Some prefer that.
Keeping weight down however is a key consideration. |
Superhawk996 |
Feb 9 2021, 12:14 PM
914 Guru Group: Members Posts: 6,469 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
All true - but - sometimes having bigger brakes results in a better pedal feeling or sense of braking power. Some prefer that. Keeping weight down however is a key consideration. Not quite correct. Pedal feel is intertwined with hydraulic displacment at the master cylinder vs. the displacment requirements of calipers. It has little to do with "bigger" brakes whatever that term may refer to (size of calipers, size of rotors, or both). Pedal feel is also greatly affected by brake pad compressability which varies widely from compound to compound. Quite often bigger brake pads with high compressability result in even more fluid displacment which degrades pedal feel for those that prefer force modulation. To compound matters, there is no ideal. Some people prefer travel modulation, others prefer force modulation. Some prefer the Goldilocks version in between. Mixing the idea that bigger brakes results in better pedal feel will lead you astray. |
Feb 9 2021, 01:55 PM
914-6 GT in waiting Group: Members Posts: 19,518 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I am with Tdskip on the premise that I’d rather use big powerful brakes lightly than all in with just adequate brakes. I like to modulate with pedal travel. It’s a holdover from my bike riding and racing. The stronger the brakes, the less hand fatigue.
dhuckabay |
Feb 9 2021, 02:17 PM
Member Group: Members Posts: 231 Joined: 14-June 20 From: Idaho Member No.: 24,379 Region Association: Pacific Northwest |
I have PCCB on four cars. Takes a while to learn how to drive with them. Will say that when it comes time for DE they are a blast. I like having all the brakes I can get. One car does 0-60 in 2.3, 60-0 in 91 feet.
Superhawk996 |
Feb 9 2021, 02:45 PM
I am with Tdskip on the premise that I’d rather use big powerful brakes lightly than all in with just adequate brakes. I like to modulate with pedal travel. It’s a holdover from my bike riding and racing. The stronger the brakes, the less hand fatigue. I get the point and I generally agree with the premise. However, I can make your "big powerful" brakes feel like (IMG:style_emoticons/default/stromberg.gif) or great by varying parameters like master cylinder size, pedal ratio, pad compressability, and in stop mu characteristics of the pad compound. The flip side of "big powerful" brakes is that they can also become extremely difficult to modulate in low friction conditions (rain, snow, sand, gravel). Pedal feel really doesn't have much to do with stopping distance performance and/or thermal fade is the point. Not completely independent but able to be tuned seperately of stopping distance to a large degree. A brake booser system only adds further tunability of feel though it doesn't apply to 914's. Newest Electronic Brake Boost systems almost completely decouple feel from performance by using pedal feel simulator to provide brake pedal feel while all actuation is done by wire. |
horizontally-opposed |
Feb 9 2021, 10:17 PM
Advanced Member Group: Members Posts: 3,443 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
…if going with boxster fronts, you should have boxster rears to balance out the equation. If going with S or A up front you should have Ms or 914-6 rears... balance your setup This isn't said often enough. So many cars get an upgrade up front and make do with whatever they had in the rear, or something "close enough." Pedal feel is intertwined with hydraulic displacment at the master cylinder vs. the displacment requirements of calipers. It has little to do with "bigger" brakes whatever that term may refer to (size of calipers, size of rotors, or both). Pedal feel is also greatly affected by brake pad compressability which varies widely from compound to compound. Quite often bigger brake pads with high compressability result in even more fluid displacment which degrades pedal feel for those that prefer force modulation. To compound matters, there is no ideal. Some people prefer travel modulation, others prefer force modulation. Some prefer the Goldilocks version in between. Mixing the idea that bigger brakes results in better pedal feel will lead you astray. ^ Great post. There is more to brake performance than stopping distances or the ability to lock the wheels up. Brake balance, modulation, pedal feel, and resistance to fade are other parameters—all of them are important to control and driver confidence—with perhaps fade resistance being the most important to me. I've encountered fade on the track and on the road, for very different reasons: Circuits work brakes harder but tend to give them a chance to cool at speed where some mountain roads never give them a break, and don't offer much in the way of speeds sufficient to cool the rotors before the next pounding. Having to drive around the brakes (or even the mere smell, a clear signal of where things are headed if you don't adjust your style and/or speed) is distinctly unfun and shakes confidence in the car not just for that drive, but future drives. This ad deals with the issue of fade really well: http://www.vehiclecraft.com/Brakes/930_upgrade.htm Why the 930 Upgrade? Why not the "Boxster" or 964 calipers? The main part of a braking system that has to deal with the heat absorption and dissipation is the brake rotor - not the calipers. So their size and mass is the main factor in choosing and upgrade. Simply put the 930 upgrade offers the largest rotor size available that will fit inside stock wheels and narrow body of most 911's and 914's. The Boxster and 964 upgrades that are being sold are based on a stock size 911 carrera rotor (24 x 289mm). While the calipers are noticeably larger, and provide more stopping power than the original small steel calipers, they actually make the main problem worse!Putting more heat energy into the same small rotor dose not solve problems, it makes them worse. This is where the 930 Upgrade really does the job. The rotor size is 12.0" x 1.25" front (300 x 32mm) and 12.18" x 1.10 rear (310 x 28mm). This is about double the heat-sink capabilities of the original rotors! Of course along with those rotors come the 4-piston 930 calipers also about doubling your stopping power. To put it in perspective, this rotor size/mass is about 85% of what a Big Red rotor upgrade is While I agree that rotor size is too often skipped over, I can't see the OP needing anything larger than the rotor in his pic with a 2.0-liter Type IV. Suspect that rotor is probably just fine up to 200 hp in most use cases. If the OP is going to keep the stock rear brakes, I'd aim for the best front caliper to match them that will work with those 911 rotors. I've been running the "Alfa" aluminum two-piston Brembos made popular in recent years and like the setup, but have been eyeing 986 calipers all around. |
Lo-Fi Version | Time is now: 27th September 2024 - 11:07 AM |
