Fuchs wheel lug nuts covers/caps?, Anybody find a set that fits? |
JamesJ |
Apr 28 2021, 11:24 PM
Member Group: Members Posts: 228 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California |
Thank you @Rob-O . I'll give Aaron a call tomorrow.
ClayPerrine |
Apr 29 2021, 06:09 AM
Life's been good to me so far..... Group: Admin Posts: 15,820 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I had my lug bolts cerakoted and have the same issue. @rhodyguy "A better solution is re-anodize the long 19mm headed lugs and use a soft socket." By soft socket do you mean one with a liner in it or a soft metal socket? Where to purchase? The only protective sockets I have found have plastic sleeves on the outside to protect the rim, but not the lug bolt head. I thought of just running a single layer of electrical tape or white medical tape on the outside of the lug bolt for removal/installation. Zims Autotechnik has soft sockets. The inner portion is soft (well, softer than steel). Ask for Aaron. FYI... it is WWW.ALLZIM.COM. And Aaron is on here as @partsguy22 . Clay |
Lo-Fi Version | Time is now: 27th September 2024 - 11:30 AM |
