Heater hose |
Heater hose |
partwerks |
Nov 26 2021, 12:14 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
What is the technical name of the hoses that goes from behind the speaker grilles, up through the cowl, and to the control valves, and the one that goes from the control valve, to the defroster vents called?
Aerostatwv |
Nov 26 2021, 12:22 PM
Member Group: Members Posts: 115 Joined: 13-July 11 From: WV Member No.: 13,315 Region Association: MidAtlantic Region |
What is the technical name of the hoses that goes from behind the speaker grilles, up through the cowl, and to the control valves, and the one that goes from the control valve, to the defroster vents called? 914 572 123 10 Air hose as per the factory parts list. Cheers, Chris |
partwerks |
Nov 26 2021, 12:53 PM
What is the technical name of the hoses that goes from behind the speaker grilles, up through the cowl, and to the control valves, and the one that goes from the control valve, to the defroster vents called? 914 572 123 10 Air hose as per the factory parts list. Cheers, Chris Like to find the other one also. 2 3/8" ID that goes from the speaker grille up to the control valves. |
914Sixer |
Nov 26 2021, 07:22 PM
914 Guru Group: Members Posts: 8,863 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
URO makes the 60 mm hoses.
Mikey914 |
Nov 27 2021, 11:28 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We call it the "long to control box hose"
You can use what it touches and what it is to search our site easily. We don't stock the paper hose that often gets kicked and crushed, but we do have a heavy duty hose that is much more difficult to damage. And the BF sale is still on ! https://914rubber.com/long-to-mixing-box-hose-1-1 |
Lo-Fi Version | Time is now: 18th April 2024 - 12:57 PM |
