FS Replated door striker sets, 4 late and 2 early sets with new screws |
bdstone914 |
Jan 25 2022, 11:43 AM
bdstone914 Group: Members Posts: 4,508 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have two early amd four late pairs of door striker plates.
They have been replated in brite clear zinc. New stainless screws and lick washers are included. The late strikers have new rubber stoppers installed. The late sets have the flange to stop the door from being pushed past the striker in the event of a side impact. These changed from the early strikers without the flange. The change happened when they added the impact reinforcements inside of the doors. The late strikers can be used on any year car. The only reason to use the early strikers is if you want to be originally correct. $50 a set for the late an $40 a set for a pair. Attached thumbnail(s) |
JeffBowlsby |
Jan 25 2022, 04:50 PM
914 Wiring Harnesses Group: Members Posts: 8,470 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Nice Bruce!
Did you fab those new rubber pads? Did the original installation include the schnoor-like washers? I dont recall seeing those before. |
bdstone914 |
Jan 25 2022, 08:42 PM
Nice Bruce! @JeffBowlsby Did you fab those new rubber pads? Did the original installation include the schnoor-like washers? I dont recall seeing those before. I bought the new pads from Bughaus.com. They are also used on Bettles of the same year range. The original screws had a nylon insert in the threads. Since these screws do not have that i added the star lock washers for countersunk screws. Blue Loctite works too. |
jettonjoshua |
Jan 27 2022, 10:14 PM
Newbie Group: Members Posts: 14 Joined: 25-February 08 From: SF Bay Area Member No.: 8,748 Region Association: Northern California |
[quote name='bdstone914' date='Jan 25 2022, 09:43 AM' post='2977324']
I have two early amd four late pairs of door striker plates. They have been replated in brite clear zinc. New stainless screws and lick washers are included. The late strikers have new rubber stoppers installed. The late sets have the flange to stop the door from being pushed past the striker in the event of a side impact. These changed from the early strikers without the flange. The change happened when they added the impact reinforcements inside of the doors. The late strikers can be used on any year car. The only reason to use the early strikers is if you want to be originally correct. $50 a set for the late an $40 a set for a pair. [/quote I'll take a late set, PM sent. |
ClayPerrine |
Jan 28 2022, 07:59 AM
Life's been good to me so far..... Group: Admin Posts: 15,395 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I would like a late set please.
Clay |
Sea Rooster |
Jan 28 2022, 08:33 AM
Member Group: Members Posts: 106 Joined: 8-March 18 From: Nashville, TN Member No.: 21,948 Region Association: South East States |
bdstone914 |
Jan 28 2022, 09:17 AM
@Sea Rooster I use new stainless steel crews and zinc plated cone washers. Yes I have them. $12 shipped. |
Lo-Fi Version | Time is now: 20th April 2024 - 05:42 AM |
