64 Pages V « < 13 14 15 16 17 > »
> 914 GT 3.6 Ferrari Build, - Mechanicals coming along, electronics soon!
ClayPerrine
post Sep 9 2022, 05:27 AM
Post #281
QUOTE(Van B @ Sep 8 2022, 09:23 PM) *
That is a very clean look! And as long as the cardboard doesn’t get wet, it should hold up beautifully! (IMG:style_emoticons/default/slap.gif)
Seriously though, I see where you’re going here and I think it will really come together well.
You beat me to it... I was going to make a joke about his CAD (cardboard aided design) process.
I actually like this better than the tubes. It looks more like something that would be done in Maranello rather than Mobile. (IMG:style_emoticons/default/lol-2.gif)
Clay
tygaboy
post Sep 9 2022, 08:17 AM
Post #282
If you're curious why I may appear overly concerned about mounting the drive train, here's a vid about replacing the motor mounts in the 360. What's awesome is that he videoed before and after to show the improvement after replacing the mount.
There's a nice before/after comparo that runs from 15:41 - 15:53.
But even with the new mounts that thing sure dances around. And that engine note!
https://www.youtube.com/watch?v=D5kS19nXgsI&t=943s
davep
post Sep 9 2022, 08:49 AM
Post #283
914 Historian
QUOTE(tygaboy @ Sep 7 2022, 10:22 AM) *
One of the designs uses a bent tube, with the bend set vertically, just behind the trans mount. This tube would see forces trying to "unbend" it, make it longer and forcing the chassis wider where its welded at the inner fender. Think "arched doorway". That vs a straight tube where forces are trying to shorten it and pull the fender weldment location inward.
I certainly like the idea of a bent beam support for the transmission. Just like a heavy equipment flatbed float is curved so that it straightens out under load instead of sagging. I was going to suggest it, but you beat me to it. When going over bumps there will also be dynamic loads that have to be allowed for.
Porsche's maxim: form follows function
tygaboy
post Sep 9 2022, 08:59 AM
Post #284
QUOTE(davep @ Sep 9 2022, 07:49 AM) *
@davep And I think Ferrari's is the exact opposite (!), or Engine Bays: Who wore it best?
(IMG:style_emoticons/default/av-943.gif)
davep
post Sep 9 2022, 09:22 AM
Post #285
914 Historian
Maybe that is why I like the pre 1990 cars so much better.
Krieger
post Sep 10 2022, 09:23 AM
Post #286
For that rectangular crossbar this would look much better than a bunch of holes/tube collecting dust and add some strenght.
rgalla9146
post Sep 10 2022, 02:45 PM
Post #287
QUOTE(Krieger @ Sep 10 2022, 11:23 AM) *
Mmmmmm......... what a nice compliment and a nice surprise.
I'm taking a bow right now !
Thank you
Rory
tygaboy
post Sep 10 2022, 04:41 PM
Post #288
While I do like the beam, it's maybe too industrial looking? So here's the newest revision - and it's my current favorite.
With that curved tube, when it's parked next to my LS build, that will let folks know they're related. (IMG:style_emoticons/default/biggrin.gif)
tygaboy
post Sep 10 2022, 04:47 PM
Post #289
Next it was on to working out the hanger bracket dimensions. There will be a couple 1.5 x 1 rectangular tubes that'll fill the open section in between the cross bars and provide a weld surface for the entire inner edge of the hanger bracket. The actual hanger will be made from 1x3 tube with an adjustable fastening system to locate and secure the transmission mount tab.
Last pic is a mock up of some of the other structure, modded to support this tubular design.
With the curved tube and the boxing at the ends, I think I can get away with no support tubes from the shock towers.
tygaboy
post Sep 10 2022, 04:56 PM
Post #290
I wanted a break from the transmission mount so I disected one of the Ferrari headers. They didn't fit but I was hoping that, maybe, if I got rid of the heat shielding, I might be able to squeeze them in. Nope...
This means aftermarket headers likely won't fit either, so custom headers it will be.
Essentially, I'll copy the factory design but move the "bundle of snakes" part forward about 3-4 inches. There's plenty of room at that point, as you can see.
I'll cut off and reuse the header flange section as it's intricately shaped. Leveraging the factory part will save a bunch of time/money.
tygaboy
post Sep 12 2022, 07:49 AM
Post #291
I spent some time on the phone with Martin discussing the header interference issue. We kicked around a few ideas until he made one of those "duh, why didn't I think of that?" suggestions. A few minutes later and: problem solved!
Before I post any pics, would any of you like to guess?
Be careful because if you come up with the solution (or maybe a better one?!), I'll be calling you all the time to help me with things like this! (IMG:style_emoticons/default/laugh.gif)
And btw, these headers are being used to prove out what'll work. Once that's decided, I'll either refurb these and do things like remove the pre-cat (that 4" diameter section between the collector and the reducer) and get them refinished or start over with an aftermarket set, now that I know what I need to do to fit them.
Cairo94507
post Sep 12 2022, 08:07 AM
Post #292
Michael
Why do the headers have to sweep forward at all?
Lilchopshop
post Sep 12 2022, 08:14 AM
Post #293
QUOTE(tygaboy @ Sep 12 2022, 09:49 AM) *
Switch sides for the header so that the pipe junction/ bundle is below the suspension mount? Would this put the outlet pipes too low relative to the axles?
tygaboy
post Sep 12 2022, 08:19 AM
Post #294
QUOTE(Cairo94507 @ Sep 12 2022, 07:07 AM) *
@Cairo94507 Michael - The goal of most N/A exhausts is to have equal length header tubing ahead of the collector. Within reason, the routing of those tubes isn't critical, but getting length, plus length of the post-collector exhaust, does make a difference. If I start the headers going back right at the engine, I'll end up with a challenge in terms of mounting the mufflers. And yes, wicked as it'd sound without them (IMG:style_emoticons/default/aktion035.gif) , it'll have mufflers.
tygaboy
post Sep 12 2022, 08:23 AM
Post #295
QUOTE(Lilchopshop @ Sep 12 2022, 07:14 AM) *
@Lilchopshop - logical suggestion, and I tried it but swapping sides makes the collision worse and if things did clear the suspension console, the header would end up lower than the engine.
sb914
post Sep 12 2022, 08:31 AM
Post #296
Surf Guru
Cut off flanges and reverse them . (IMG:style_emoticons/default/confused24.gif)
post Sep 12 2022, 09:42 AM
Post #297
Resident German
QUOTE(tygaboy @ Sep 12 2022, 06:49 AM) *
Raise the engine an inch or two.
tom.esh
post Sep 12 2022, 10:26 AM
Post #298
Heat and bend to fit? Or a big hammer. Just kidding about the hammer.
tazz9924
post Sep 12 2022, 10:27 AM
Post #299
A good ole dent.
Van B
post Sep 12 2022, 11:37 AM
Post #300
Since you’re not playing by euro 4 emissions on this, why not move the cat further down stream so you can get rid of some bulk and reduce heat in the bay?
- Lo-Fi Version Time is now: 23rd November 2024 - 10:52 AM
