64 Pages V « < 18 19 20 21 22 > »
> 914 GT 3.6 Ferrari Build, - Mechanicals coming along, electronics soon!
tygaboy
post Nov 9 2022, 07:02 PM
Post #381
Proof of concept of the "center" tab bracket. This is just a first effort based on a card board template and while I got pretty close, I have a couple changes to make to get a better fit. Plus the final version of all the tabs will be cut from 3/16" plate.
The cradle's upper bar will bolt to the outside of this where another tab will be, while the lower bar bolts to the inside of this with its other tab farther inboard. So, yes, the cradle walls will be slightly angled.
And that ramp that heads forward under the floor will help establish the front section of the under-drive train skid plate/flat floor. I hope to be able to sneak tunnels on both sides with a difusser at the rear.
tygaboy
post Nov 9 2022, 07:05 PM
Post #382
Here's the CAD rear view of the cradle geometry showing the 1.25" tubing and a 1" OD bung that'll bolt to the above mentioned set of tabs.
willieg
post Nov 10 2022, 09:53 AM
Post #383
Chris
Seeing yesterday what you are doing with the cradle and bracket, I do have some thoughts. Yes, there is one in every crowd. Cut (2) pieces of 1.25 tubing, 1” long. Fish eye one of the ends of the 1” tubing on both pieces. Weld the fish eye end to the ends of your cradle. Weld a nut onto the other end of the 1” piece of tubing. Run a bolt through your bracket into the nut welded onto the short tubing to secure your cradle the the bracket. BTW: awesome build!
Andyrew
post Nov 11 2022, 05:18 AM
Post #384
Spooling.... Please wait
QUOTE(tygaboy @ Nov 9 2022, 05:02 PM) *
Jebus… how tight fitting do you need it Chris? (IMG:style_emoticons/default/smile.gif) I mean it’s just gonna be welded, wouldn’t you want a nice 1/16” gap in there for weld space? Man that looks good!
tygaboy
post Nov 11 2022, 02:29 PM
Post #385
QUOTE(Andyrew @ Nov 11 2022, 03:18 AM) *
@Andyrew Andrew, You've met me, right? (IMG:style_emoticons/default/laugh.gif) As I mentioned after my visit to Singer, my shop mantra is now "Plus or minus less than yesterday!"
I'm happy with the latest design's fit.
Cairo94507
post Nov 11 2022, 03:36 PM
Post #386
Michael
Wow- that is a very nice fit. (IMG:style_emoticons/default/beerchug.gif)
dr914@autoatlanta.com
post Nov 11 2022, 03:48 PM
Post #387
I have a 914 but always wanted a ferrari so made my 914 into one: LOLAttached Image Attached Image
tygaboy
post Nov 11 2022, 05:35 PM
Post #388
And here are the final parts in 7 ga (3/16"), fitted with approximate width bungs, just to get a look at whereabouts everything will be positioned.
The undersides of the lower cradle tubes will serve as the location for the drive train skid plate.
Krieger
post Nov 11 2022, 06:16 PM
Post #389
Very nice! Now I understand Martin's sketch of the removable mount. Does the third leg of the mount go to the long or is the exhaust the way?
tygaboy
post Nov 11 2022, 06:34 PM
Post #390
QUOTE(Krieger @ Nov 11 2022, 04:16 PM) *
@Krieger - Andy, Martin's latest sketch was close but changes were made, based on real dimensions. So at this point, the plan is that there will be similar tabs added low on the suspension console that will pick up a wide bung that's aligned with a 3" x 1" cross bar that runs in that gap under the drive train and ties up to the two cradle tubes.
I hope to have the whole cradle mocked in place this weekend so clarifying pics should be coming soon.
Or, just swing by and see it!
horizontally-opposed
post Nov 11 2022, 07:34 PM
Post #391
When "mere" engine mounts are prettier than whole cars… (IMG:style_emoticons/default/aktion035.gif)
tygaboy
post Nov 12 2022, 02:30 PM
Post #392
One Ferrari-in-a-914 engine cradle kit. Some machining and welding required.
tygaboy
post Nov 12 2022, 06:09 PM
Post #393
Today Martin and I went to another buddy's shop to borrow his lathe and mill.
First was the lathe, to face both ends of the bungs, then measure and trim them to final length.
tygaboy
post Nov 12 2022, 06:10 PM
Post #394
Next, it was into the mill with the cradle tubes to cut the... wait for it... bung hole! (IMG:style_emoticons/default/bootyshake.gif) (IMG:style_emoticons/default/shades.gif)
tygaboy
post Nov 12 2022, 06:13 PM
Post #395
Nothing like having the proper tools available. Super nice result!
The outer edges of that excess material will be trimmed back and the remaining will be wrapped around the bung ahead of welding.
Cairo94507
post Nov 28 2022, 08:40 AM
Post #396
Michael
Looking forward to some new pictures on this after 2 weeks of no World. (IMG:style_emoticons/default/beerchug.gif)
tygaboy
post Nov 28 2022, 09:21 AM
Post #397
You'd think I'd have made a ton of progress in the past couple weeks. Well, if you count design changes, I did!
Remember, this cradle will be attached to the drivetrain and the entire set up then offered up to the chassis. So, after seeing the "vertical tabs" model mocked into the chassis, I realized the odds of being able to get all of the mounting bungs to slip into those slots, at the same time, at the necessary angle, on my contraption jack set up would be, um, "low".
Why don't I think these things through on paper before I make parts? (IMG:style_emoticons/default/headbang.gif)
Look at the how things mount in the 914. In the 911. All the mounts are horizontally oriented. I am such a doofus sometimes. OK, many times...
The good news is all I had to do was rotate the cradle tubes 90 degrees, update the fire wall tab system to account for a horizontal orientation and cut the new parts. With that done I could fixture up the cradle tubes and get things tacked.
Here are a few pics of the fixture set up being used to build each cradle side, then to position the cross bar. Again, having this table is like cheating.
tygaboy
post Nov 28 2022, 09:29 AM
Post #398
And here's the horizontal tab set. One thing I did account for is that the fire wall isn't necessarily 90 degress to the chassis. To account for that, I used a tab/slot approach with the tabs and mounting plates so that once the tabs are tight against the fire wall and the cradle is mocked into position, the mounting plates have enough slop that they can rotate to their "happy place" within the tabs and self-locate to the exact position needed.
See? Sometimes I'm all over a good approach! (IMG:style_emoticons/default/laugh.gif)
Note, too, that I went after the edges of the mounting tabs with my little metal router. It makes for a really nicely finished part.
tygaboy
post Nov 28 2022, 09:33 AM
Post #399
Cradle mocked in place, successfully demonstrating that all the measuring was accurate. I have the needed clearance at the alternator and the cross bar sits just where I wanted it, with plenty of clearance to the drivetrain.
tygaboy
post Nov 28 2022, 09:42 AM
Post #400
Next, it was on to the engine mount brackets. Here's the current design.
What's neat is that you can cut the holes with a bit over 180 degrees remaining and "snap" the piece over the tube. It really helps simplify mocking it into position as it pretty much holds itself in place.
There will be one of these plates on each side of the mount with a vertical plate between them.
Note that I routered the opening but didn't yet get to the outside edges.
- Lo-Fi Version Time is now: 23rd November 2024 - 05:43 PM
