64 Pages V « < 24 25 26 27 28 > »
> 914 GT 3.6 Ferrari Build, - Mechanicals coming along, electronics soon!
Cairo94507
post Dec 16 2022, 05:38 PM
Post #501
Michael
Game changer for sure. (IMG:style_emoticons/default/beerchug.gif)
tygaboy
post Dec 17 2022, 09:09 AM
Post #502
QUOTE(BillC @ Dec 16 2022, 03:17 PM) *
QUOTE(tygaboy @ Dec 15 2022, 03:55 PM) *
Noodling on ideas for boxing, with this design leading at the moment. The height of the opening allows access to the mounting fastener. Looks kinda cool, too.
That looks great, but have you checked to see if you have clearance with the engine in place to put a socket on that bolt? If the engine is wider than the cradle at that point, you might not have room to get a wrench or socket in there.
Not saying I've ever been bitten by sorta detail before, but.... (IMG:style_emoticons/default/headbang.gif)
@BillC - As you can see from this "planning stage" pic, the engine width isn't a worry. The only thing that I expect could prevent accessing the rear cradle bolts from above would be the headers - which are yet to be developed. But you make a fair point, for sure. That said, worst case, I can make a custom tool that will allow me to get at that cradle nut. Or come up with some sort of captured nut/nut plate and eliminate the concern all together. All TBD at this point.
tygaboy
post Dec 17 2022, 05:58 PM
Post #503
Today was getting the cradle under the engine and jacking everything into position so I can locate the engine mounting side and main plates on the cradle.
This requires fully suspending the engine in the exact location I want it.
I ended up slinging the front from the the engine hoist while the rear is mounted at the trans. That right there is a Ferrari drive train held where it's gonna end up! (IMG:style_emoticons/default/aktion035.gif)
And OMG, the QuickJacks are awesome. All the way up and the motor slides under. Drop it to the low position and it's a perfect height to intall the drive train. So. Much. Better!
tygaboy
post Dec 17 2022, 06:01 PM
Post #504
And happiest of all it that my measurements were accurate: all clearances are just what I wanted - most critically, at the alternator. (IMG:style_emoticons/default/beerchug.gif)
tygaboy
post Dec 17 2022, 06:03 PM
Post #505
Even the motor mount height inside the mount side plates is just where it's supposed to be! Probably only one more day of work and this first phase of "mount the drive train" will be concluded. It's been a long time coming, eh?
post Dec 17 2022, 06:26 PM
Post #506
Resident German
How much clearance do you have on the firewall? Those valve covers look awfully close.
tygaboy
post Dec 17 2022, 06:56 PM
Post #507
QUOTE(SirAndy @ Dec 17 2022, 04:26 PM) *
@SirAndy Andy - It's a bit deceiving in the pics, there's plenty of room. I did have to "massage" the fire wall just ahead of the cover, but not too much.
tygaboy
post Dec 18 2022, 02:10 PM
Post #508
@SirAndy - Andy - There's a bit more room than the tape shows but, yes, there's clearance.
tygaboy
post Dec 18 2022, 02:15 PM
Post #509
Motor mount "top plates" are trimmed to size and everything is now nicely centered. Ahead of final positioning and welding, I'm going to substitute a metal spacer for the rubber mount so as to eliminate any deflection/out of plane caused by the rubber. This'll guarantee the top plates end up parallel to the cast aluminum engine mount surface.
mgp4591
post Dec 18 2022, 03:01 PM
Post #510
Chris, will substituting metal for the rubber isolator put more stress on the aluminum mounting ears and possibly cause cracks or failure in the castings?
tygaboy
post Dec 18 2022, 04:03 PM
Post #511
QUOTE(mgp4591 @ Dec 18 2022, 01:01 PM) *
@mgp4591 - Sorry, I should have been more clear: I'm only substituting the metal to serve as a temporary fixture to locate and ensure the top plate is dead even with the base of the aluminum mounting ears. Once welding is complete on the cradle mounts, the spacer comes out and the factory rubber mounts go back in.
tygaboy
post Dec 19 2022, 05:56 PM
Post #512
Today was committing to the drive train position and getting the engine mounts welded to the cradle.
First up was making the above-mentioned spacer set up to substiture for the Ferrari engine mount and serve as the positioning fixture.
I plasma cut a couple appropriate plates and, unbelieveably, found the perfect sized spacer in the scrap pile! Karma, baby!
Here's the spacer set up next to the Ferrari mount. Note, both are upside down.
tygaboy
post Dec 19 2022, 06:00 PM
Post #513
Next was to get the drive train suspended in the proper location - that was fun...
Once that was set up and all levels and angles were checked and rechecked, the engine mount top plates were tacked to the upper cradle bars. Then the cradle was removed from the car for bench welding.
The first step there was to level the top plates to each other and verifiy them as level to the main cross bar. Yep, everything check out just as hoped expected. (IMG:style_emoticons/default/laugh.gif)
Then the side plates got squared and clamped and all those parts tacked in place.
tygaboy
post Dec 19 2022, 06:01 PM
Post #514
On to making up some gussets for the side plates and fixturing them for tacking.
tygaboy
post Dec 19 2022, 06:04 PM
Post #515
The side plate gussets got the edge router treatment, as well as some corner cut outs to help prevent trapping stuff that may find it's way in there.
Yep, style points for stuff no one will ever see. It's how we do things "At the Red Barn".
(What could those quotes possibly imply...?) (IMG:style_emoticons/default/idea.gif)
tygaboy
post Dec 19 2022, 06:07 PM
Post #516
Final welding yet to go but here it is: the Ferrari engine cradle.
That was WAY more complicated and WAY more work that I'd ever imagined it would be.
But the good news is this means that tomorrow, the drive train will be fully mounted in the chassis and it'll be on to the next chapter of the build! (IMG:style_emoticons/default/cheer.gif)
Cairo94507
post Dec 20 2022, 08:22 AM
Post #517
Michael
(IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/smilie_pokal.gif)
KELTY360
post Dec 20 2022, 09:14 AM
Post #518
914 Neferati
DaVinci would approve.
Maybe the car should be named Leonardo.....or at least the drive train cradle.
Tferrer
post Dec 20 2022, 10:13 AM
Post #519
Beautiful work. You better be careful, Chris- Before you know it you'll have a wait list for folks wanting one of your builds! (IMG:style_emoticons/default/chowtime.gif)
Steve
post Dec 20 2022, 10:35 AM
Post #520
QUOTE(Tferrer @ Dec 20 2022, 08:13 AM) *
Sad... but that drive train is cheaper than a 993 3.6 motor and 915 trans.
https://www.ebay.com/itm/354286038626?hash=...%3ABFBM-O6ThqZh
- Lo-Fi Version Time is now: 23rd November 2024 - 11:05 AM
