Driving light questions ?, trying to sort non-running issue with Pilot lights. |
porschetub |
May 8 2022, 04:55 PM
Advanced Member Group: Members Posts: 4,696 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Bought a set of these years ago got them mounted but never got them working after fixing old fog light wiring.
A few questions ; Looking along left to right with the fuse board mounted which is the relay for these ? On a USA spec car what function of the light triggers the relay....I'am thinking low beam but not sure ? ,the compliance police in my country the rule used to be activation only on high beam from the light switch,and the driving lights need to be controlled via a switch which my car obviously has. Have done research and found some helpful info but still just trying to clear up a few things. TIA ,as really need to sort as I'am going to go nuts (IMG:style_emoticons/default/sad.gif) |
Mark Henry |
May 8 2022, 05:09 PM
Going? (IMG:style_emoticons/default/biggrin.gif)
Try this here. It tells you how to look for the relay near the bottom of the page. |
May 8 2022, 07:09 PM
Custom Member Group: Members Posts: 24,560 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Driving lights, switch pulled out, headlights on low beam.
porschetub |
May 8 2022, 10:04 PM
Bought a set of these years ago got them mounted but never got them working after fixing old fog light wiring. A few questions ; Looking along left to right with the fuse board mounted which is the relay for these ? On a USA spec car what function of the light triggers the relay....I'am thinking low beam but not sure ? ,the compliance police in my country the rule used to be activation only on high beam from the light switch,and the driving lights need to be controlled via a switch which my car obviously has. Have done research and found some helpful info but still just trying to clear up a few things. TIA ,as really need to sort as I'am going to go nuts (IMG:style_emoticons/default/sad.gif) Thanks Mark I remember that article but couldn't find it as I came upon it when I bought the Pilot lights,bloody Haynes manual is no good (IMG:style_emoticons/default/mad.gif) . Rich yep thought that was the way,cheers. I have researched a bit more and think its an earth issue as I believe it is wrong ,if my relay is ok I reckon I should have control from the high beam as my car was imported to my country and would have to be complied that way. Cheers will report back. |
porschetub |
May 9 2022, 08:23 PM
Bought a set of these years ago got them mounted but never got them working after fixing old fog light wiring. A few questions ; Looking along left to right with the fuse board mounted which is the relay for these ? On a USA spec car what function of the light triggers the relay....I'am thinking low beam but not sure ? ,the compliance police in my country the rule used to be activation only on high beam from the light switch,and the driving lights need to be controlled via a switch which my car obviously has. Have done research and found some helpful info but still just trying to clear up a few things. TIA ,as really need to sort as I'am going to go nuts (IMG:style_emoticons/default/sad.gif) Thanks Mark I remember that article but couldn't find it as I came upon it when I bought the Pilot lights,bloody Haynes manual is no good (IMG:style_emoticons/default/mad.gif) . Rich yep thought that was the way,cheers. I have researched a bit more and think its an earth issue as I believe it is wrong ,if my relay is ok I reckon I should have control from the high beam as my car was imported to my country and would have to be complied that way. Cheers will report back. Found the wiring using that article Mark supplied,found relay buggered and swapped out from my extensive stock but it appears that I have no connection to trigger it so need to pull some dash switches and have a poke around which is a PITA (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/mad.gif) . |
porschetub |
May 22 2022, 02:03 PM
Bought a set of these years ago got them mounted but never got them working after fixing old fog light wiring. A few questions ; Looking along left to right with the fuse board mounted which is the relay for these ? On a USA spec car what function of the light triggers the relay....I'am thinking low beam but not sure ? ,the compliance police in my country the rule used to be activation only on high beam from the light switch,and the driving lights need to be controlled via a switch which my car obviously has. Have done research and found some helpful info but still just trying to clear up a few things. TIA ,as really need to sort as I'am going to go nuts (IMG:style_emoticons/default/sad.gif) Thanks Mark I remember that article but couldn't find it as I came upon it when I bought the Pilot lights,bloody Haynes manual is no good (IMG:style_emoticons/default/mad.gif) . Rich yep thought that was the way,cheers. I have researched a bit more and think its an earth issue as I believe it is wrong ,if my relay is ok I reckon I should have control from the high beam as my car was imported to my country and would have to be complied that way. Cheers will report back. Found the wiring using that article Mark supplied,found relay buggered and swapped out from my extensive stock but it appears that I have no connection to trigger it so need to pull some dash switches and have a poke around which is a PITA (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/mad.gif) . (IMG:style_emoticons/default/cheer.gif) found the issue after pissing around in the wrong direction (as you do ) black wire to 56a wasn't connected on the 11 pin light switch...all is golden now (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/aktion035.gif) . Fog lights or in my case driving lights work as per factory spec so well pleased with these units. |
Cairo94507 |
May 23 2022, 06:57 AM
Michael Group: Members Posts: 9,703 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Congratulations. This is a terrific community and I especially appreciate when the OP posts the solution so we all learn. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 19th April 2024 - 04:17 PM |
