Collapsed lifter? |
Collapsed lifter? |
DRPHIL914 |
Jun 10 2022, 11:47 AM
Dr. Phil Group: Members Posts: 5,808 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Root_Werks |
Jun 10 2022, 12:49 PM
Village Idiot Group: Members Posts: 8,424 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Uh oh, that picture paints a clearer state of things. I was way off, does look like either a bent valve or dropped seat. From the picture, that one spring looks compressed a little more than the others. If you can get a differential gauge set on that cyl, you will probably hear air through the intake (that's the intake valve right?)
rhodyguy |
Jun 10 2022, 12:57 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Presume the other 7 are waiting to happen. Sorry for your woes.
Shivers |
Jun 10 2022, 01:14 PM
Senior Member Group: Members Posts: 2,674 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I was rooting for the flattened lifter. Darn.
930cabman |
Jun 10 2022, 01:19 PM
Advanced Member Group: Members Posts: 3,544 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Have you done a compression check or a leakdown test?
Def sorry for your woes, especially with the summer season just coming on. |
porschetub |
Jun 10 2022, 01:54 PM
Advanced Member Group: Members Posts: 4,725 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Sorry to say, but based on your description (especially the noise), you're probably looking at a valve seat that let go. Here's a very useful tool that you can feed either through the spark plug hole or manifold. It's useful for many other jobs too and is less than $20 delivered. Please note that this one works on an android phone. If you have an iPhone get a different one. https://www.amazon.com/gp/aw/d/B071HYRPND?p...ob_b_asin_title Best wishes with the fix. (IMG:style_emoticons/default/agree.gif) valve seat loose and valve stuck down classic signs ,IMO if solid lifter you would have a bent pushrod but instead the hyd lifter collapsed ?,Iam a little concerned about pushrods appears they are not the steel ones's as one other member pointed out. I would pull the engine and pop of that head off,if it is this issue you need to check the out for valve seat issues on the other head. Not good news but could have been a lot worse (IMG:style_emoticons/default/sad.gif) . |
JMT |
Jun 10 2022, 02:15 PM
Newbie Group: Members Posts: 36 Joined: 19-August 16 From: Ca Member No.: 20,316 Region Association: None |
Thanks guys for all the well wishes. I'll probably just take the head off and hope for the best.
Root_Werks, yes intake on #4 rhodyguy I am thinking what you're thinking...what about the 7 others? porschetub, those are solid lifters, they just look hydraulic, crazy huh, They are from web cam. The pushrods are aluminum and didn't bend. Is it safe to assume the seat gave way and the valve is hanging up? That's what I'm hoping for. These heads had 44 intake and 38 exhaust and had some work done to them. Maybe jumping the gun but any thoughts on new heads? Mike Damone: I woke up in a great mood; I don't know what the hell happened. (Fast Times at Ridgemont high) |
rhodyguy |
Jun 10 2022, 03:59 PM
I honestly don't know what to tell you. This is the point where project creep flows in and the cash flows out.
930cabman |
Jun 10 2022, 04:18 PM
I honestly don't know what to tell you. This is the point where project creep flows in and the cash flows out. Exactly, with 50 years old stuff, you may want to look into new heads. My local old school head guy has passed on a couple sets of heads I have brought to him for reconditioning |
brant |
Jun 10 2022, 04:35 PM
914 Wizard Group: Members Posts: 11,739 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Most of the guys that do head work will no longer accept the job on used heads because they can no longer stand behind the work on old castings.
So new heads are “almost” the only way The other 7 seats are suspect now that you know the part has aged out from too many heat cycles |
porschetub |
Jun 11 2022, 03:08 PM
Most of the guys that do head work will no longer accept the job on used heads because they can no longer stand behind the work on old castings. So new heads are “almost” the only way The other 7 seats are suspect now that you know the part has aged out from too many heat cycles (IMG:style_emoticons/default/agree.gif) certainly the rest may do the same,were the replacement seats put in correctly or maybe the heads are too weak/soft to support them ?. The shop that used to do my VW heads won't touch air cooled ones now. |
JMT |
Jun 11 2022, 04:10 PM
I'm thinking It's better to just get new heads. I've been doing a little searching here for options. What are your guys thoughts? AMC? AA?
sportlicherFahrer |
Jun 12 2022, 09:21 AM
Nothing to see here. Group: Members Posts: 1,098 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest |
I'd jump on one of the FB groups and find Tabari Andrade. Not sure if he's a member here. He's in CA, and can source/machine parts. When I was getting parts together for my engine he mentioned he can build a set of heads out pretty nice. Worth looking into.
brant |
Jun 12 2022, 10:22 AM
I'm thinking It's better to just get new heads. I've been doing a little searching here for options. What are your guys thoughts? AMC? AA? I haven’t researched lately I believe the new heafs are fine But if you want the big valves. You’ll have machine them still and have the seats changed. Didn’t Len sell them. He would be a trustworthy machinist too. |
JMT |
Jun 12 2022, 10:35 AM
Sold out, these would be the closest thing to what I have.
https://aapistons.com/collections/stock-per...eads-44x36-pair |
Jake Raby |
Jun 13 2022, 12:13 PM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Any of the new heads require better components installed to be trustworthy. This held true with the AMC Spanish made heads, as well as these newer units made in China.
Valves and springs are the biggest question mark, as well as valve seat material, and seat installation. Len stopped rebuilding OE head castings a long time ago. If you buy his heads based on either of the new castings available, he is reworking those in many ways, balancing the chambers, installing proven hardware and etc. Once he's done with them, I'd say that the AMC or China heads are on par with each other. Out of the box from either manufacturer is a crapshoot. The crapshoot associated with OE head castings is even bigger, because over 45 years they've been overheated, hacked on, welded, have stripped threads, and will pull exhaust studs in most cases. Heads do have a service life, even 911 heads. |
JMT |
Jun 13 2022, 12:41 PM
Thanks Jake. Sounds like Len is the way to go.
JMT |
Jun 13 2022, 01:15 PM
LN Engineering website.
NOTE: Due to limited availability and high demand, we will not be offering our Camper Special, RS+, or LE200 heads for purchase outside of our engine kits. |
GregAmy |
Jun 13 2022, 01:22 PM
Advanced Member Group: Members Posts: 2,383 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
The lack of affordable rebuilders and drying up of spare parts is making engine swaps that much more do-able...and that much more attractive.
My vote is for the Honda K20Z3 with drive-by-wire. Massive support for those engines and easy peasy build to 200 wheel ponies. I'm wiring up a 2008 Civic Si with AEM Inifity 5 engine management as we type (we get ~230 wheel with cams and exhaust). |
mgphoto |
Jun 13 2022, 06:15 PM
"If there is a mistake it will find me" Group: Members Posts: 1,363 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Lo-Fi Version | Time is now: 27th September 2024 - 06:40 AM |
