What just happened ?, Final update 6/14/22 |
brant |
Jun 13 2022, 06:42 PM
914 Wizard Group: Members Posts: 11,739 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I’ll look also.
Might have one Sorry for the troubles |
brant |
Jun 13 2022, 06:43 PM
Duplicate
914e |
Jun 13 2022, 06:56 PM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
Jim, The way you can tell is if you try to rotate the axle shafts with the car in gear a broken CV will allow the axle to spin somewhat freely. Your mechanic will know for sure. Easy fix if that's what it is. I've broken a couple and the car revs in gear but won't move an inch. UPdate: Car is up mon the lift. With car in gea, we turned the passenger side wheel. The driver side does not turn. The consensus is the pinion gear is broke.....looking for a temp replacement until I can get Dr Evil to repair. Pinion? or spider gears? |
76-914 |
Jun 13 2022, 07:13 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,611 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Jim, I have a spare 901 sitting here if you want to borrow it. It's just gathering dust so use it as long as you like. And thanks for the Starbuck's card. You didn't have to do that. (IMG:style_emoticons/default/beerchug.gif)
jim_hoyland |
Jun 13 2022, 09:39 PM
Get that VIN ? Group: Members Posts: 9,418 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
jim_hoyland |
Jun 13 2022, 09:42 PM
Jim, I have a spare 901 sitting here if you want to borrow it. It's just gathering dust so use it as long as you like. And thanks for the Starbuck's card. You didn't have to do that. (IMG:style_emoticons/default/beerchug.gif) Thanks Kent. That would allow me time to repair mine or find a rebuild, plus I have to move my car out of the shop. The shop is a one man operation and space is a premium Will PM you in the morning Thanks again ! (IMG:style_emoticons/default/smile.gif) |
jim_hoyland |
Jun 13 2022, 09:47 PM
Today, with the car on the lift, and the tranny in 2nd, the driver side wheel would not turn when the passenger wheel was turned.
Then I was shown how it should have worked using a VW on a second lift |
Jun 14 2022, 03:02 AM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Yes, that's the wheel. What bout the axles? Look at what the axles do. Before you tear the transmission apart...
--DD |
jim_hoyland |
Jun 14 2022, 03:43 AM
jim_hoyland |
Jun 14 2022, 05:52 PM
Final consensus is the pinion. Dr Evil contacted my mechanic and confirmed the nature of the failure. Dr Evil stated ”They fail for many reasons. 40+ yrs of fatigue, period. I have a shelf of pinion heads from boxes I’ve fixed.‘
Thanks to all who opined on this situation. Plus I learned more about other possible failures as well as ways to test for failure. Attached image(s) |
Montreal914 |
Jun 14 2022, 06:56 PM
Senior Member Group: Members Posts: 1,675 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
So, which pinion failed?
The spider gears inside the differential assembly? Or the actual pinion from the ring and pinion? Clearly different repairs... (IMG:style_emoticons/default/sad.gif) That being said, maybe it is time for an overhaul... (IMG:style_emoticons/default/dry.gif) |
Root_Werks |
Jun 16 2022, 05:22 PM
Village Idiot Group: Members Posts: 8,424 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
That sucks Jim. If it was me, I'd pull just the trans, can even leave the heater boxes on, pull the muffler, slide trans off (motor supported of course) and get the trans gone through. Shortest turnaround time to get back to driving.
Besides, if I pull an engine, it always turns into "while I'm in there..." (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 08:23 AM |
