got stranded .... |
got stranded .... |
DRPHIL914 |
Apr 18 2023, 12:30 PM
Dr. Phil Group: Members Posts: 5,808 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
UPDATE: up and running … Cleaned sockets with some sandpaper wrapped around a toothpick… spread the pins slightly and bam… The familiar buzz of the fuelpump is back… Anyway, once the new relays are in fm 914rubber I will put those in and carry the wehrles as spare… @spoke … thks yr drawing and explanation. That one is much simpler to understand for a non electrician Happy it was not more than that (although I feel stupid as I could have fixed it myself on the road… anyway first time I used roadassistance and their service has been tested now (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) Thank you all Dax (IMG:style_emoticons/default/beer.gif) awesome! sometimes its a simple thing we have overlooked, i had that happen, about 5 years ago upon reassembly after paint and body work, the ground wire to the fuel pump somehow disconnected, and no start issue, spent 3 hours going thru the whole test and diagostic proceedure for the ignition system and relay board to find out if i hand just checked continuity for the pump circuits id have saved a lot of time, but its never a waste i was able to confirm the rest of the system was working just fine. |
Lo-Fi Version | Time is now: 27th September 2024 - 09:16 AM |
