| chmillman |
Oct 16 2025, 04:56 AM
Member ![]() ![]() Group: Members Posts: 253 Joined: 15-June 24 From: Switzerland Member No.: 28,183 Region Association: Europe
Thinking about pulling my rocker panels and having them repainted - they are looking a bit dingy and grayish. Plus all the discussions here about looking underneath…
They are currently held on by the plastic rivets - I think - they don’t look great and probably not salvageable. I thought I would put the panels back on with pop rivets, which seem like a more solid solution - black ones are available - I don’t mind having to drill them out if I want to remove the panels again at a later date. I don’t anticipate doing it often. Is there anything that argues strongly against this? |
| emerygt350 |
Oct 16 2025, 05:12 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,410 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I use aluminum rivets, drill out real easy. I have a grey car so the color doesn't matter. I pull mine once or twice a year.
| bdstone914 |
Oct 16 2025, 05:14 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,211 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I just installed a set with aluminum pop rivets. I don't mind the aluminum look. It was quick ans easy. If it ever bugs me I will use a black paint pen on the heads
| cassmcentee |
Oct 16 2025, 06:04 AM
Member ![]() ![]() Group: Members Posts: 243 Joined: 12-July 18 From: Squaw Valley, CA Member No.: 22,304 Region Association: Central California
| Millerwelds |
Oct 16 2025, 06:06 AM
Pleepleus ![]() ![]() ![]() Group: Members Posts: 736 Joined: 24-June 08 From: Grass Valley, CA Member No.: 9,206 Region Association: Northern California |
I am in the process of replacing all the miss matched hardware with M5 rivnut's. The rockers, front and rear valences, headlight covers, sill plates, etc. One allen wrench covers everything. Using black on mine.
| 930cabman |
Oct 16 2025, 02:38 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,361 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
I use aluminum pop rivets, a dab of black paint on the head.
done |
| chmillman |
Oct 16 2025, 02:47 PM
OK, thanks all, I can easily get black ones here anyway. Before I start pulling the old ones out - what diameter are they? 3.2mm? 4mm?
| Front yard mechanic |
Oct 17 2025, 06:22 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,399 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None
| rick 918-S |
Oct 17 2025, 06:33 AM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,140 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
914 Rubber has the plastic Rivets
| bdstone914 |
Oct 17 2025, 07:19 AM
| Root_Werks |
Oct 17 2025, 09:31 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,862 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
Dunno if this helps, I'm using SS rockers which are thicker metal than stock. I don't use rivets. Not needed. Sure looks cleaner and way easier to remove and clean.
| FlacaProductions |
Oct 17 2025, 09:53 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,104 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
@Root_Werks - did the stainless come pre-drilled or did you have to line 'em up and drill the mounting holes? How did you finish them?
| Root_Werks |
Oct 17 2025, 10:12 AM
@Root_Werks - did the stainless come pre-drilled or did you have to line 'em up and drill the mounting holes? How did you finish them? Powder coated satin black. Holes on the bottom were drilled as well as the fender holes. No rivet holes were drilled. The panel is rigid enough the rivets aren't needed. Not a very good picture from years ago. You can sort of see no rivets: Attached image(s)
| Literati914 |
Oct 17 2025, 11:02 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,172 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Black screws easy on and off ( stupid little plastic rivets are for people with little fingers) Those take screws. He is talking about the rocker panels not the carpet strips I used black screws in both places, worked fine and I prefer this solution for ease of R/R - but not before messing around with the infuriating little nylon rivets. (IMG:style_emoticons/default/headbang.gif) |
| Montreal914 |
Oct 17 2025, 11:10 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,973 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
@chmillman
Not sure you got your answer on the hole diameter in the body for the rivets. I measured a few and got 3.3 - 3.5mm for the holes. I would assume more readily available(?) 1/8” (3.125mm) rivets could work. Then again these are probably made in China so would they actually be of metric OD? (IMG:style_emoticons/default/confused24.gif) I was thinking about using the plastic ones. Good luck! |
| FlacaProductions |
Oct 17 2025, 11:15 AM
@Root_Werks - thanks - that's helpful.
| bkrantz |
Oct 17 2025, 08:04 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,545 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Black screws easy on and off ( stupid little plastic rivets are for people with little fingers) Those take screws. He is talking about the rocker panels not the carpet strips I used black screws in both places, worked fine and I prefer this solution for ease of R/R - but not before messing around with the infuriating little nylon rivets. (IMG:style_emoticons/default/headbang.gif) I think screws are the way to go for anyone who plans to (or just doesn't avoid) getting their 914 dirty. In that case, removing the rocker covers with every serious wash. Garage queens can have rivets. |
| chmillman |
Dec 8 2025, 05:26 AM
In the end I went with screws - because I found the right ones. 3.5mm x 13 long, black, low profile round head, and with a T10 torx driver. And to top it off under the black coating, the screws are... stainless. I didn't believe that at first, but lo and behold, you can't pick them up with a magnet. And I found them at the local Home Depot-style do-it store... (IMG:style_emoticons/default/biggrin.gif)
What's cool is that you just screw them right in - they're the perfect size, no drilling out of the body holes needed. The heads are lower than the rivets and a little wider. There was a significant amount of crud under the rocker panels - I don't think they had been removed since the car was restored in 2011. I was happy to see that the longs were still nice and clean - no evidence of rust anywhere. Probably won't remove the rockers again that often, maybe once every couple of years... |
| Aayala |
Dec 8 2025, 10:40 AM
Newbie ![]() Group: Members Posts: 40 Joined: 7-July 25 From: Austin Tx Member No.: 28,874 Region Association: South East States |
In the end I went with screws - because I found the right ones. 3.5mm x 13 long, black, low profile round head, and with a T10 torx driver. And to top it off under the black coating, the screws are... stainless. I didn't believe that at first, but lo and behold, you can't pick them up with a magnet. And I found them at the local Home Depot-style do-it store... (IMG:style_emoticons/default/biggrin.gif) What's cool is that you just screw them right in - they're the perfect size, no drilling out of the body holes needed. The heads are lower than the rivets and a little wider. There was a significant amount of crud under the rocker panels - I don't think they had been removed since the car was restored in 2011. I was happy to see that the longs were still nice and clean - no evidence of rust anywhere. Probably won't remove the rockers again that often, maybe once every couple of years... Do you mind taking a picture of where you installed them and the condition of what was under the rocker panels? Would be curious to how they look. |
| rgalla9146 |
Dec 8 2025, 02:45 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,890 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Depends on your car and how strict you are. My 1970 has white plastic rivets as original. I don't know if they're available today. Stock later cars with black plastic thresholds get black plastic rivets. Or whatever suits you for cleaning and maintenance. |
Lo-Fi Version | Time is now: 9th December 2025 - 11:40 AM |
