| TRP |
Dec 1 2025, 04:36 PM
Member ![]() ![]() Group: Members Posts: 135 Joined: 2-September 23 From: Morgan Hill, CA Member No.: 27,559 Region Association: None
Hello,
I'm looking to buy a replacement cooling fan for the 2056 I'm building. The fan that came with the donor core is missing three fins. Also looking for the two lower shroud flaps for the 914 cooling shroud. Again, the donor motor is missing the little lower tin flaps. Thank you, Ted Pierson |
| 914Sixer |
Dec 1 2025, 06:30 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,352 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
914Rubber has the cooling flaps
| GregAmy |
Dec 1 2025, 06:44 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,599 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
Ted, I have a stock 914 cooling fan and housing, and it may have flappers*; I replaced the one in my racer (no heat needed) with a bus one (they use gas heaters). The housing is powdercoated gray, though. Photo before I replaced it.
PM me and we can coordinate. *As noted above, 914 Rubber has new replacements |
Lo-Fi Version | Time is now: 2nd December 2025 - 08:42 AM |
