> Heater Core that fits in the fresh air box with minimal trimming!
captain awesome
post Dec 8 2025, 12:07 PM
So I originally planned to use a Ford heater core but kept thinking there has to be something that will fit without requiring a "bump out" of the lid. Turns out a Honda s2000 fit great!
I trimmed the inner lip flush. The upper rain cover needed maybe a 1/2" removed to get it all to sandwich together.
The outlets swivel with an internal o-ring so you can adjust the direction or placement of the hoses.
captain awesome
post Dec 8 2025, 12:08 PM
More pics
Ninja
post Dec 8 2025, 02:12 PM
Thanks for posting!
That does fit pretty nice!
bdstone914
post Dec 9 2025, 04:48 AM
bdstone914
It will be interesting to see if the fresh air box can take the heat. I once put a housing in the ultra sonic and heated the water to 180 degrees F. The box looked like a Salvadore Dali clock.
The other concern is the weight you are adding. Most air boxes have cracks at the two mounting points at the top. I have added two more mounting holes and nuts as the flanges have the holes already.
captain awesome
post Dec 9 2025, 08:31 AM
QUOTE(bdstone914 @ Dec 9 2025, 04:48 AM) *
There are plenty of examples of others using heater cores in the stock fresh air box, so I don't think there's any real concern of it melting. It's also a smaller core than most have used so it seems less likely to crack than most. I will however keep an eye on that, possibly reinforce the mounting area to ensure it lasts longer than a few trips.
bdstone914
post Dec 9 2025, 10:05 AM
bdstone914
QUOTE(captain awesome @ Dec 9 2025, 08:31 AM) *
It is the plastic on the housing that cracks as the assembly is only supported at two points and the fan is an under hung weight that stresses the mounting points.
I know others have mounted heater cores in blower boxes.
Hope it works for you.
I don't know why the blower box melted. Maybe a combination of heat and ultra sonic vibration.
I have a Subi conversion and have thought about adding heat. But not much is needed in California
4 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 9th December 2025 - 11:40 AM
