Hello My Name is Tony and I have DWD, caught a bad case in the electrical way |
lapuwali |
Oct 17 2005, 11:10 AM
Hm. I've pulled apart a half-dozen Lucas wiring harnesses and only found crimped connections. And this is on older (early 60s) BMC and "Stanard" (the marque, not the adjective) cars. I've only had one MG, though, and that was 20 years ago. Are these the "cup-style" bullets, where the wire goes into the cup? I've seen those in catalogs, but never actually on a car. I didn't think Lucas could really descend any lower than I've already seen. This is the company that used plastic inline fuse holders OEM because they added a couple of circuits beyond the four fuses they allowed for in the fusebox, on high-volume cars... Yes, you need expensive crimp tools, and said tools are more expensive than a soldering iron. However, they won't burn you or the wire's insulation, and they don't need electric power to work. IMHO, everything needs to be perfect for soldering to work, too. The iron needs to be the right temp, the wire and whatever you're connecting to need to be clean, and you need to provide some total strain relief after the fact, as soldered connections are structurally weak as well as brittle. Soldering works fine for attaching components to a printed circuit board, but for free-standing wires and connectors, crimping is far better. |
Lo-Fi Version | Time is now: 27th September 2024 - 11:44 AM |
