Engine Removal/Cleaning, Pressure washer... |
John VS |
Oct 3 2003, 10:45 PM
Newbie Group: Benefactors Posts: 36 Joined: 22-September 03 From: Pleasant Hill CA Member No.: 1,187 |
I plan to remove the stock 76 2L in order to fix oil leaks, etc. I have read posts here about using brake cleaner to clean the engine. I have access to a pressure washer. Will this be an effective way to clean the engine (with degreaser, etc.)? What PSI works best (this unit has 2200 PSI)? Any things to watch out for when removing the engine (besides dropping it on my head)?
Bleyseng |
Oct 3 2003, 11:24 PM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Don't forget to undo the tranny ground strap!
If you are going to pressure wash the engine, do it before you drop it. You can pull all the FI stuff out first, lableing the wiring harnes with tape tags. It makes it simpler when you put it back. Geoff |
John VS |
Oct 3 2003, 11:33 PM
Thnx Geoff. Why pressure wash engine before dropping it? (this sounds like its going to be a "duh").
McMark |
Oct 4 2003, 12:54 AM
It's most dirty on the bottom and being in the car makes it easier to get at the bottom. (IMG:style_emoticons/default/wink.gif)
tod914 |
Oct 6 2003, 08:07 PM
see if you can rent a steam genie. i tried a pressure washer on mine, it only moved the greese around. steam is the way to go. Or, hook up the pressure washer to your hot water washer machine outlet in the house.
that might work just as well. |
rhodyguy |
Oct 6 2003, 09:57 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
you got leaks? you will look like an old time coal miner. find a co that does automotive steam cleaning on a hoist. the BEST money you will spend. after you buy can after can of cleaner (go back to the store because you ran out, looking like a piece of shit), and 15 rolls of paper towels (off to the store AGAIN), chem burns, a driveway that you will have to clean, spending more time wiping down your tools than you spend under the car... oh, the wife catching you putting your coverals in the washer. EVERY DAY (IMG:style_emoticons/default/ohmy.gif)
kevin |
John VS |
Oct 7 2003, 12:14 AM
Thanks for the tips Tod & Kevin. I agree that steam is a better way to go. I'm looking at people who steam clean engines and find only a few references in detailing ads. Seems there is one in Walnut Creek that may work out. Do you know of any others in the east bay (N. Calif.)that do this kind of work? John VS
Lo-Fi Version | Time is now: 27th September 2024 - 12:10 PM |
