back to Queenie's FI, Vegas was more fun |
onespeedboy |
Oct 14 2003, 05:23 PM
Newbie Group: Members Posts: 12 Joined: 25-September 03 From: Bolivia SA Member No.: 1,195 |
I've returned from my road trip and am gonna take another shot at Queenie's FI setup.
Can anyone help me to interpret the discrepancies I encounter between this diagram and her system? 1)diagram shows breather hose from oil filler going to a black thingy(?) and then to the plenum. Queenie's goes straight to the air cleaner. No PCV valve to be seen (where would a PCV normally live, anyhow?). 2)Diagram shows decel valve's 5mm hose routing to the same "thingy". Queenie's rig has decel valve plumbed straight to the plenum 3)Queenie's car has neither breathers in the heads nor an anti-flashback valve. Any info welcome. thanks OSB Attached thumbnail(s) |
Charles Deutsch |
Oct 14 2003, 06:19 PM
Unregistered |
I can't help you directly but have you downloaded the factory fuel injection manual from here ? I've been looking at mine (114 pages) and it has a huge amount of information and many photos of the fuel injection setup and it even has a troubleshooting chart. Good luck.
Oct 14 2003, 06:28 PM
Resident German Group: Admin Posts: 41,815 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(onespeedboy @ Oct 14 2003, 04:23 PM) 1)diagram shows breather hose from oil filler going to a black thingy(?) and then to the plenum. Queenie's goes straight to the air cleaner. No PCV valve to be seen (where would a PCV normally live, anyhow?). 2)Diagram shows decel valve's 5mm hose routing to the same "thingy". Queenie's rig has decel valve plumbed straight to the plenum 3)Queenie's car has neither breathers in the heads nor an anti-flashback valve. i "think" the black thingy is just a splitter. that's what they used on mine. going to the air-cleaner directly is fine. some engines (like mine) didn't come with the breatherholes in the heads. soooo, no anti-flashback valve, no need to worry about that. Andy |
ChrisReale |
Oct 14 2003, 07:08 PM
What year is her car? I remember that some dont have PCV valves. If you want, I can take a picture of my engine compartment....might take me a bit to do that tho... The pcv valve should be on the oil filler neck base. The hose from that goes into the "elbow" that you are seeing (black rubber thing going into phlenum) The smaller of the holes on the elbow goes to the Decel valve, which looks like a fuel pressure regulator, but is by the MPS.
Queenie |
Oct 14 2003, 07:11 PM
Society Is A Hole Group: Members Posts: 383 Joined: 14-July 03 From: SLO-CA Member No.: 908 |
QUOTE(ChrisReale @ Oct 14 2003, 05:08 PM) What year is her car? It's a '76, with the full complement of emissions control crapola. Hoses, hoses everywhere. |
ChrisReale |
Oh, my hoses would be i bit different then....you hoser (IMG:style_emoticons/default/laugh.gif)
Queenie |
Oct 14 2003, 07:15 PM
QUOTE(ChrisReale @ Oct 14 2003, 05:11 PM) Oh, my hoses would be i bit different then....you hoser All I wanted to do was drive a fun Porsche...but I GOT HOSED!!!! (IMG:style_emoticons/default/laugh.gif) |
Bleyseng |
Oct 14 2003, 07:20 PM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
QUOTE(onespeedboy @ Oct 14 2003, 03:23 PM) 1)diagram shows breather hose from oil filler going to a black thingy(?) and then to the plenum. Queenie's goes straight to the air cleaner. No PCV valve to be seen (where would a PCV normally live, anyhow?). 2)Diagram shows decel valve's 5mm hose routing to the same "thingy". Queenie's rig has decel valve plumbed straight to the plenum 3)Queenie's car has neither breathers in the heads nor an anti-flashback valve. Any info welcome. thanks OSB 1.None is needed since you still have the air injection 2.Its a hard rubber elbow with two sizes of fittings for the decel valve hoses 3. It shouldn't if its still stock Geoff |
RustyWa |
Oct 14 2003, 10:33 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
QUOTE 1)diagram shows breather hose from oil filler going to a black thingy(?) and then to the plenum. Queenie's goes straight to the air cleaner. No PCV valve to be seen (where would a PCV normally live, anyhow?). 2)Diagram shows decel valve's 5mm hose routing to the same "thingy". Queenie's rig has decel valve plumbed straight to the plenum 3)Queenie's car has neither breathers in the heads nor an anti-flashback valve. My turn...I actually have a '75 that had smog stuff on it. 1 - No PCV valve, '75 & '76s are different. Crankcase ventilation goes from oil (OEL) filler to large connection on air filter housing. 2 - Decel valve. 2 large connections. one on air filter housing and the other goes to the port on the plenum, below the throttle body. It's right below the MPS connection on the plenum. The small connection on for the decel valve goes right next to the large decel valve connection on the plenum. 3 - No flashback valves or breathers in the heads. Just the air injection ports, hard piped. |
RustyWa |
Oct 14 2003, 11:00 PM
Here's a photo of my engine bay....ignore the crud.....and the poor photo editing software....
RustyWa |
Oct 14 2003, 11:05 PM
Here's a photo of the backside of the non-PCV valve oil filler... There is just a baffle on the back side. The hose connects upstream of the throttle plate, as my previous photo shows.
onespeedboy |
Oct 15 2003, 09:01 AM
thanks for your time with the photos and explanation, Eric. Very helpful.
Mica's rig is identical, save for the air injection hard lines. Looks like I've got the charcoal can backwards. Can you confirm that the small line on the charcoal can runs out of the engine bay to the front of the car, presumably to a fuel tank vent? I must comment that this bbs is the most active and helpful I've encountered. Thanks again |
Bleyseng |
Oct 15 2003, 09:25 AM
Yes, the small line off the canister runs to the fuel tank lent.
RustyWa |
Oct 15 2003, 01:34 PM
I'm actually not to sure I have the charcoal canister flowing the correct direction. I turned it the way I have it because the other end has a snap on lid. If I connected the air filter box to this side...it seemed to me that quite a bit of unfiltered air was getting by this lid. It leaked air around the lid when I blew air into the port....
Anyways...that's my story. |
Lo-Fi Version | Time is now: 27th September 2024 - 12:18 PM |
