Routing the Speedo Cable |
joea9146 |
Oct 15 2003, 05:07 PM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
When you run the Speedo cable into the tunnel does it stay in the tunnel all the way
to the front and than pop out, or does it pop out soon as it enters the tunnel and run on top of the tunnel where the wiring harness is. Its been a while since I had this hooked up and can not recall how it routes . |
Oct 15 2003, 05:18 PM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
On top of the tunnel most or all of the way, as I recall. Right next to the wiring harness.
--DD |
seanery |
Oct 15 2003, 05:20 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
Is it a tight squeeze through the firewall?
Looks like a big head on that cable!! |
joea9146 |
Oct 15 2003, 06:00 PM
Thanks
Lo-Fi Version | Time is now: 27th September 2024 - 12:02 PM |
