Performance Coatings, Where to have it done??? |
Britain Smith |
Oct 15 2003, 09:22 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
I am wanting to have the 2.0L heads on my turbo motor coated with a thermal barrier. Does anyone have any suggestions on where to have this done and how much it should/will cost? Better yet, does anyone have a shop that does this?
-Britain |
TimT |
Oct 15 2003, 09:29 PM
Swaintech jet hot, and airborne keep poking up
Swain actualy offers some tech stuff... even though most of these coatings manufacturers websites suck swain wins for me |
Bleyseng |
Oct 15 2003, 09:34 PM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Is that a good idea? I thought piston tops was ok but the heads?
Geoff |
Mueller |
Oct 15 2003, 11:30 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
Pay to have it done by a professional is all I can say
.....my coating on the top of my "homedone" pistons is flaking off. The heads held up okay, so I must have done something wrong to the piston surface or prep...... of course, running the car with an A/F ratio of 17:1 might have caused some of the damage.......glad I got the car onto a dyno before "real" damage happened. |
DuckRyder |
Oct 16 2003, 06:10 AM
Avatars Mode: OFF because of the recalcitrant few. Group: Benefactors Posts: 767 Joined: 8-January 03 From: Georgia Member No.: 110 |
I've had good luck with Jet Hot.
I'm thinking Turbo headers will need the "2000" coating. A set of V-8 headers are 225.00 inside and out IIRC. |
Blynes |
Oct 16 2003, 06:41 AM
Member Group: Members Posts: 68 Joined: 19-January 03 From: Savannah, GA Member No.: 169 |
I used Jet-Hot on my headers.
Great job. Easy to deal with. Bill |
RON S. |
Oct 16 2003, 07:16 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
Britain,
Try calling a company called PolyDyn performance coatings.They are out in Houston I think.Web site is www.polydyn.com I used them back in the early '90s while doing some weekend mini-stock racing.They did many internal engine parts for me,of various types.An example on a piston.Thermal barrier on top,wear coating on skirts,and a teflon coating underneath the piston only came to about $10.00 per piston.We also did an oil absorbant coating on all the rod&main brg's.You'll have to adjust for proper clearances or you'll sieze a crank like we did the first time we toyed with coatings.Once we sorted that issue out and started over,I will say our engine did run 5-10 degrees cooler with the coatings while we raced it. They'll send you free info. Ron |
Lo-Fi Version | Time is now: 27th September 2024 - 12:05 PM |
