VIN questions |
VIN questions |
roundboy914 |
Oct 16 2003, 07:36 PM
Member Group: Members Posts: 210 Joined: 16-October 03 From: Chicago, IL Member No.: 1,251 |
I was looking at my title, and was wondering if there was a way to find out about the original factory options/body color/interior color on the car using the VIN code. Any info?
seanery |
Oct 16 2003, 07:38 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
you need a Cardex. You can get it through PCNA or maybe even your local dealer.
Rusty |
Oct 16 2003, 07:39 PM
Wanted: Engine case GA003709 Group: Admin Posts: 7,952 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
Unfortunately, no.
There are some generalizations that can be made about your car, that can be based on what year your car is. Otherwise, to really be sure (as sure as you can with ~30 year old records maintained at Porsche), you need to order a Certificate of Authenticity. This piece of paper is AKA a "Cardex". Current costs for a Cardex is running about a hundred dollars. hope this helps, Rusty (IMG:style_emoticons/default/smoke.gif) |
VegasRacer |
Oct 16 2003, 07:51 PM
ELVIRA Group: Benefactors Posts: 8,624 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
If you check the plate rivited to the left door hinge post you can use the paint code to tell you the original color of the car.
Lo-Fi Version | Time is now: 27th September 2024 - 12:02 PM |
