914/4 calliper verses Volvo 4-pot caliper, picture and weights.......... |
Mueller |
Oct 29 2003, 04:20 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
Timo had asked about the weight of the 4 piston caliper for the 200 series Volvos (offered for both solid and vented rotors)
Not as much of a difference as one would think (IMG:style_emoticons/default/smile.gif) Attached image(s) |
dakotaewing |
Oct 29 2003, 04:33 PM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
Mike,
What is the difference in size (sq. in) in the pads? Thom |
914Timo |
Oct 30 2003, 01:30 AM
******* Group: Members Posts: 743 Joined: 13-January 03 From: Finland Member No.: 137 Region Association: Europe |
Interesting. Only 2 lbs.
But, they are heavy. I have seen and tested them. We have lots of Volvos here (IMG:style_emoticons/default/sad.gif) You get 2 extra pots with Volvo calipers. They weight a litle more, but if you can live with that what are the other advantages ?? I dont know if they are cheep there, but they are quite a cheep here. That is one advantage. I think this is a conversion you can make, but the benefits are very questionable. |
skline |
Oct 30 2003, 09:02 AM
I have a set of these for my Chalon V-8 project. Mine are for the vented rotors. The pads are literally twice the size of the stock 914 pads. Much larger than the 320I pads and are more squared. I think they look better. Here is what mine came out like.
skline |
Oct 30 2003, 09:03 AM
Lets try it again.
Part Pricer |
Oct 30 2003, 09:26 AM
Believe everything I post Group: Benefactors Posts: 1,825 Joined: 28-December 02 From: Danbury, CT Member No.: 35 |
Here's a pic of 240 calipers for vented disks. Notice the size of the pads.
davep |
Oct 30 2003, 10:26 AM
914 Historian Group: Benefactors Posts: 5,195 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
So what about fitment problems? Do the just bolt up and work? Do you need spacers of any sort?
DaveP |
swood |
Oct 30 2003, 12:42 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
You need a second pair of brake lines to them as well don't you?
JWest |
Oct 30 2003, 12:54 PM
OK, so what do "A" calipers weigh? And the later aluminum Porsche (944 T, Big Red, Boxter)?
Brad Roberts |
Oct 30 2003, 01:05 PM
Damn.
Should have weighed Olavs 944T calipers before we installed them. Swood... most the guy's who sell he Volvo conversion parts sell a brass adapter for 1 line into the those two holes. DaveP. The Volvos bolt up to the Carrera struts (3.5 inch spacing) B |
Mueller |
Oct 30 2003, 01:25 PM
QUOTE The Volvos bolt up to the Carrera struts (3.5 inch spacing) mine bolt up to the /4 and early 911 struts (3" spacing) |
Brad Roberts |
Oct 30 2003, 01:27 PM
Cool. I stand corrected. I must be thinking of the Nissan Pathfinder calipers. They look identical to the Volvo but dont have the funky line arrangement and fit the same rotor.
B |
Downunderman |
Oct 30 2003, 03:38 PM
Senior Member Group: Members Posts: 852 Joined: 31-May 03 From: Sydney, Australia Member No.: 766 Region Association: Australia and New Zealand |
You can avoid the extra line by drilling through the base of each piston bore at about 45 deg from each side so that on each side the fluid flows from the lower cylinder to the upper. I did it this way and it works.
Aaron Cox |
Oct 30 2003, 04:16 PM
hmm... i have a volvo 240 (IMG:style_emoticons/default/wink.gif)
ChrisReale |
Oct 31 2003, 01:27 AM
What year Volvo's did these come on?
SteveSr |
Oct 31 2003, 02:42 PM
Member Group: Members Posts: 203 Joined: 7-October 03 From: Knox,In. Member No.: 1,223 |
Ok,does the stock 17MM piston or 911 19MM piston in the master cylinder have enough volume to move the eight pistons in front and two out back without bottoming? (IMG:style_emoticons/default/confused24.gif)
Steve |
1973914 |
Oct 31 2003, 03:59 PM
Member Group: Members Posts: 353 Joined: 16-May 03 From: Washington, DC Member No.: 703 |
are you able to use a larger rotor? Bigger pads are fine if you are using them once or twice, but repeated heavy use at speed will simply overheat the smaller rotors. There is a reason the larger calipers/pads have larger rotors and/or more exocitc materials (carbon)....
Brad Roberts |
Oct 31 2003, 08:56 PM
Steve,
The 19mm works fine. As far as the rotor goes.. stock SC is the only one I'm aware of that fits. The Carrera rotor is too wide for the pads. Damn.. your only the second person to understand that you cant just slap a bigger caliper/pad on a rotor without some issues. I have been trying to say that about the BMW calipers for several years now. B |
SteveSr |
Nov 4 2003, 09:49 AM
Would the heat issue really be an issue if your only on the street or autox?
On the track I can see it happening........ Steve |
Brad Roberts |
Nov 4 2003, 12:02 PM
Depends on "your" streets. If I take your car out on HWY9 near Santa Cruz Ca. with BMW calipers and hang it all out. I promise fade just as bad as the stock calipers if not worse.
I'm sure Tn has some roads where heavy braking is required. For daily street use and AutoX they will be fine... but then I question why the person installed them if that is all they where going to use the car for. B |
Lo-Fi Version | Time is now: 27th September 2024 - 01:20 PM |
