Replacement electrical heat available? |
tracks914 |
Nov 3 2003, 06:35 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
QUOTE(MarkV @ Nov 1 2003, 09:25 PM) That is a A/C unit. It has an evaporator coil inside it & has condensate drain lines. Heaters don't have condensate drains. (IMG:style_emoticons/default/confused24.gif) Shows how much I know (IMG:style_emoticons/default/blink.gif) I was told the heater heated coolant and was pumped into this heat exchanger to heat the cab of the car. That might explain some of the odd holes drilled into the wheel wells of my car! (IMG:style_emoticons/default/ar15.gif) Anyone need a A/C condensor? (IMG:style_emoticons/default/lol3.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 01:21 PM |
