Recommend Camshaft |
StratPlayer |
Mar 11 2003, 12:22 AM
StratPlayer Group: Members Posts: 3,293 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
What is the best option for a camshaft for a 2.0 76 D Jet? (IMG:style_emoticons/default/confused24.gif)
Alfred |
Mar 11 2003, 01:30 AM
Unregistered |
The stock camshaft. See http://www.pelicanparts.com/catalog/shopca...engine_main.htm for prices .
Alfred |
Mark Henry |
Mar 11 2003, 09:36 AM
Web cam AND the matching lifters.
Stock grind or they do have a stock FI compatable hipo cam (#73, I think) but you may have to adjust your FI for it to work proper. (IMG:style_emoticons/default/beer3.gif) |
Mike9142.0 |
Mar 11 2003, 11:01 PM
Member Group: Members Posts: 219 Joined: 29-January 03 From: Phoenix, AZ Member No.: 208 Region Association: Southwest Region |
What are the lift and duration of a stock cam for a 73 D jet?
StratPlayer |
Mar 11 2003, 11:08 PM
Correct me if I'm wrong please
Cam intake valve lift (in): 0.38 Cam exhaust valve lift (in): 0.361 |
Alfred |
Mar 12 2003, 12:04 AM
Unregistered |
StratPlayer,
I emailed Web Cam recently and asked them for the specs on their replacement for the stock 914 camshaft and they replied: "These are the specs on the stock cam: .302 @ the cam on the intake ( 7.67 mm) .283 @ the cam on the exhaust ( 7.19 mm) Duration @ .050 intake is 210° Duration @ .050 intake is 206° Intake opens -3° Intake closes 33° exhaust opens 31° exhaust closes -5° " You also have to consider the rocker arm ratio. Alfred |
Lo-Fi Version | Time is now: 27th September 2024 - 08:20 AM |
