Another quality product from JWE! |
JWest |
May 28 2008, 10:02 AM
VaccaRabite |
May 28 2008, 12:34 PM
En Garde! Group: Admin Posts: 13,554 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I am tempted...
Will this work with a Euro Race header installed? Let me know. Looks can be deceiving, but it looks like I would have header pipes running right where the shifter bar goes. ??? I dunno. Zach |
McMark |
May 28 2008, 12:37 PM
Shift bar is custom. You have to weld in a piece. Andy used a straight piece. You can use a stock piece.
seanery |
May 28 2008, 12:39 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
The kit looks awesome James!
It's making me want to get going on my 914 again! LOL |
JWest |
May 28 2008, 01:09 PM
I am tempted... Will this work with a Euro Race header installed? Let me know. Looks can be deceiving, but it looks like I would have header pipes running right where the shifter bar goes. ??? I dunno. Zach The shift rod will be above the header, but the u-joint will be close to the rear header pipe on the Eurorace system. The rear shift rod may need to be extended forward to move the u-joint into the space between the two left header tubes. |
scottb |
May 28 2008, 03:29 PM
who wants a PEZ?! Group: Members Posts: 1,993 Joined: 27-December 02 From: south-(not north)-wick, MA Member No.: 32 Region Association: North East States |
i now have my linkage installed (was done along with the $5k motor). i had previously put in the rennshift.
i am very pleased with the combination. i agree with andy's comment that this is not a 2008 transmission but as close as you will get with the 35 year old gear box we have to work with. that being said, i have a 4 cylinder with a side shift which is a different installation process than that which andy had with the 6 due to the shape of the shift rod. there are more issues to accomodate with the curve and the engine support bar. ed (ejm) may pipe in here with his comments as he was the one to put this sucker in for me (and very well might i add) as i don't have any welding skills. i would highly recommend the entire system. cheers, scott |
May 28 2008, 08:52 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
James, or anyone....
Is someone making a replacement steering shaft ujoint??? I replaced everything, including new bronze steering rack bushings and new bearings....now I have a slight click in the steering u-joints... I need two, perfect, NEW, not used, ujoints. Rich |
914werke |
May 28 2008, 09:54 PM
"I got blisters on me fingers" Group: Members Posts: 10,560 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
i have a 4 cylinder with a side shift which is a different installation process than that which andy had with the 6 due to the shape of the shift rod. there are more issues to accomodate with the curve and the engine support bar. scott This is what Im curious about. You still end up with a curved R. shift rod on a /4 w/side shift ? Wouldnt a straight rod be preferable for the function of the u-joints? Is the eng X bar the issue? |
JWest |
May 28 2008, 09:59 PM
i have a 4 cylinder with a side shift which is a different installation process than that which andy had with the 6 due to the shape of the shift rod. there are more issues to accomodate with the curve and the engine support bar. scott This is what Im curious about. You still end up with a curved R. shift rod on a /4 w/side shift ? Wouldnt a straight rod be preferable for the function of the u-joints? Is the eng X bar the issue? No, the engine is the issue. The real solution is to install a six (IMG:style_emoticons/default/biggrin.gif) . Sorry... The kit eliminates half of the bends in the factory tube, and what is left does not flex much. You end up with a solid snap into gear rather than the mush of factory linkage. |
JWest |
May 28 2008, 10:01 PM
James, or anyone.... Is someone making a replacement steering shaft ujoint??? I replaced everything, including new bronze steering rack bushings and new bearings....now I have a slight click in the steering u-joints... I need two, perfect, NEW, not used, ujoints. Rich Dunno, the u-joints I use are the same diameter and spline, but are a little longer so they won't interchange for the steering. |
brp986s |
May 28 2008, 10:15 PM
Member Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
James, or anyone.... Is someone making a replacement steering shaft ujoint??? I replaced everything, including new bronze steering rack bushings and new bearings....now I have a slight click in the steering u-joints... I need two, perfect, NEW, not used, ujoints. Rich I bought a new one from porsche last year - $100. It produced a pronounced bind in steering so I took it out and put my crappy ol' joint back in which works fine. Go figger. If you put in rack spacers you might get a click. |
partwerks |
Oct 31 2010, 06:36 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
I'm wondering if the shift rod linkage part of it, will work with a Subie conversion as the shift rod goes under the cradle that the engine sits in and has some bends to go under it, if this setup will work?
Lo-Fi Version | Time is now: 27th September 2024 - 01:24 PM |
