Where do i find those Euro front turn signal kits ?, also can somone tell me about where to get some sways? |
mikeyboy_85 |
Sep 9 2007, 07:37 AM
Member Group: Members Posts: 82 Joined: 24-May 07 From: australia Member No.: 7,758 |
Hey, i have an imported 914 and wanted to get the euro signals for the front to make the parker seperate from the turn signal.. and also the car handles not to bad but i think it could benifit from sway bars, could someone please tell me what brand to get etc and is installation hard?
skline |
Sep 9 2007, 08:28 AM
Camp914 for the signal kit and as for sway bars, Weltmeister, stock or whatever you can afford. The installation is fairly easy on any of them.
So.Cal.914 |
Sep 9 2007, 08:30 AM
Camp 914, for the blinkers, you will see the ad above in the banner.
Sway bars will help. Performance Products, Automobile Atlanta for starters. Installation is not bad, if you have Q's, you have come to the right place. |
rhodyguy |
Sep 9 2007, 08:57 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
do you want oem or after market swaybars? good, used, complete, oem bars should be readily available thru the classifieds here, at narp, 914club, and pelican. new bushings and you're good to go. check your front control arms to make sure they have tabs for the droplinks.
k |
mikeyboy_85 |
Sep 9 2007, 09:07 AM
do you want oem or after market swaybars? good, used, complete, oem bars should be readily available thru the classifieds here, at narp, 914club, and pelican. new bushings and you're good to go. check your front control arms to make sure they have tabs for the droplinks. k well what would u suggest as the best option?? and what do these tabs look like ?? i really don't how a sway bar works. . . can someone explain it to me ?? |
rhodyguy |
Sep 9 2007, 09:35 AM
the front bar passes thru the body under the fuel tank. you have to pull the tank to install it. the tab is pictured on the front control arms i removed from a car yesterday. you can see where the bottom of the droplink attaches in one picture and the top in the other.
k Attached image(s) |
So.Cal.914 |
Sep 9 2007, 11:16 AM
Like Skline mentioned, I run Weltweister and I have been happy, and the price is right. But you can spend more. It's a spring steel rod that runs from side to side, drop links tie the two sides together.
DEC |
Sep 9 2007, 01:48 PM
Senior Member Group: Members Posts: 630 Joined: 10-November 05 From: Rehburg Member No.: 5,104 Region Association: Germany |
the front bar passes thru the body under the fuel tank. you have to pull the tank to install it. the tab is pictured on the front control arms i removed from a car yesterday. you can see where the bottom of the droplink attaches in one picture and the top in the other. k (IMG:style_emoticons/default/agree.gif) Here any pics |
DEC |
Sep 9 2007, 01:52 PM
Rick_Eberle |
Sep 9 2007, 03:57 PM
Member Group: Members Posts: 390 Joined: 14-January 04 From: Geelong, Australia Member No.: 1,558 |
I converted the indicators myself. Just cut an aluminium plate to fit the indentations in the light housing, and drill a hole in the bottom to fit the light from the side marker. That will work as your parking light.
Where in Australia are you? I'm in Geelong. |
mikeyboy_85 |
Sep 9 2007, 06:32 PM
I converted the indicators myself. Just cut an aluminium plate to fit the indentations in the light housing, and drill a hole in the bottom to fit the light from the side marker. That will work as your parking light. Where in Australia are you? I'm in Geelong. Hey, Im out near lilydale, i would love to see your 914! Mine is the only one that i have seen in Oz cheers michael |
914-8 |
Sep 9 2007, 07:07 PM
Senior Member Group: Members Posts: 802 Joined: 23-January 06 From: Cal Member No.: 5,461 Region Association: None |
I converted the indicators myself. Just cut an aluminium plate to fit the indentations in the light housing, and drill a hole in the bottom to fit the light from the side marker. That will work as your parking light. Where in Australia are you? I'm in Geelong. Do you have any pics of your conversion? Not quite sure what you mean about "fitting the light from the side marker." The side marker light seems to be a part of the round plastic side marker assembly that can't easily be removed. Thanks! |
John |
Sep 9 2007, 07:46 PM
Mine are not like the factory made (the factory ones looked to be some sort of casting with a rounded reflector shape for the bulb.
Mine are made of 2 pieces of 1/8" plastic (maybe lexan). One piece is cut to fit in the housing and is curved on top to match the lens. It is used to block light from the rest of the housing. My second piece has two holes that sit on the locater pins that are part of the housing. This second piece is where I mounted a bulb socket. I bought bulb sockets and 5W bulbs at my flaps. I made mine 19 or 20 years ago, shortly after buying my car. |
mikeyboy_85 |
Sep 10 2007, 04:40 AM
here is my front end . . . i am told it has a 70's 911 front end, Would it effect me buying a 914 sway bar??
cheers michael Attached thumbnail(s) |
mikeyboy_85 |
Sep 10 2007, 04:43 AM
I take it that my car has not had sway bars installed ??
blitZ |
Sep 10 2007, 06:40 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
Looks like your car has never had a front sway bar. There is a good article at Pelican to show you how. However, there is already the tab on your A arm for the drop link, so it will be a little less work. It's a very worthwhile upgrade.
mikeyboy_85 |
Sep 10 2007, 07:43 AM
rhodyguy |
Sep 10 2007, 07:48 AM
oem with what appears to be fresh anodizing. real sharp!
k |
mikeyboy_85 |
Sep 10 2007, 09:49 PM
What are the advantages of the Weltweister? i was looking at them in pelican and they seem well priced, i also say the rear OEM one as well. Is there any complete kits for the rear cause i noticed that the rear sway brackets are no longer availble?
thanks michael |
Rick_Eberle |
Sep 11 2007, 10:41 PM
Do you have any pics of your conversion? Not quite sure what you mean about "fitting the light from the side marker." The side marker light seems to be a part of the round plastic side marker assembly that can't easily be removed. Thanks! Actually, when I really think about it, it was only the wiring that got used... I switched to H4 headlights, and they had an optional parking light socket, and I put that into the bottom of the indicator housing. |
Lo-Fi Version | Time is now: 27th September 2024 - 12:41 PM |
