FYI: Official Alien Build thread Started 2003, Alien Resurection is underway. Flywheel is finished - transaxle is bolted - Starter works |
dinomium |
Jan 22 2006, 12:58 PM
Git on a chair son, all the good stuff is goin over yer head! Group: Benefactors Posts: 2,777 Joined: 2-January 03 From: Bremerton, WA Member No.: 74 Region Association: Pacific Northwest |
Right on RIck! I really look forward to meeting you and seeing the car in Portland this summer!!
rick 918-S |
Jan 23 2006, 08:54 PM
Hey nice rack! -Celette Group: Members Posts: 20,785 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I'll post pictures later, but I pulled the left cam tower off tonight. I found a broken valve spring on # 8 intake valve. More news later, I've got to get something to eat. (IMG:http://www.914world.com/bbs2/html/emoticons/popcorn[1].gif)
seanery |
Jan 23 2006, 08:55 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
(IMG:http://www.914world.com/bbs2/html/emoticons/popcorn[1].gif) isn't dinner!
(IMG:http://www.914world.com/bbs2/html/emoticons/pizza.gif) and (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) are much better (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
rick 918-S |
Jan 24 2006, 12:30 AM
That's what we had! Pizza! Hey all, Here's what I found tonight. If you read back through this on going saga, you'll see I had a piece of what looked like a stainless steel valve shim float into the oil pump on my way back from the MWC "04". It locked the pump and stopped the serpentine belt in a horrid screeech! I couldn't imagine that the metal made it to the pump from the valves, So I took a chance and put a used pump back in and fired the car up. Well it's never really been a 100% since I first started the car. So after discovering the broken intake spring on # 8 tonight I'm assuming the engine had a broken spring since I brought it home from the salvage yard. So since I built the car I've been trying to tune around the valve spring failure. The best news is The head looks good, and the better news is the BORES look perfect! Any of you that were impressed by the power and grunt will appreciate the direction I'm going now. With a fresh motor and a Brad Mayeur fresh transaxle with the HB gear set I got from Aaron! Attached image(s) |
rick 918-S |
Jan 24 2006, 12:31 AM
Here's the valve! (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
rick 918-S |
Jan 24 2006, 12:33 AM
Here's # 8 bore. (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif)
Howard |
Jan 24 2006, 12:41 AM
Incontin(g)ent Member Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None |
Rick, you are truely demented for even starting this project. I can respect that (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
TJB/914 |
Jan 24 2006, 06:17 AM
Mid-Engn. Group: Members Posts: 4,380 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
Rick you are my hero. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) I want to grow up to be just like you. (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif)
Keep up the good fight. Tom |
spare time toys |
Jan 24 2006, 07:35 AM
While it is on the stand can you get photos of how you got rid of the tube that runs down the front of the block for oil fill, also by the oil filter where you moved the sender to. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
ClayPerrine |
Jan 24 2006, 08:26 AM
Life's been good to me so far..... Group: Admin Posts: 15,901 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
jim912928 |
Jan 24 2006, 08:30 AM
Senior Member Group: Members Posts: 1,487 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
**** **** HEADLINES **** **** Area 51 moves to MN!
ClayPerrine |
Jan 24 2006, 08:34 AM
Should we call the National Inquier?
Root_Werks |
Jan 24 2006, 08:38 AM
Village Idiot Group: Members Posts: 8,484 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Aaron Cox |
Jan 24 2006, 09:58 AM
transaxle update (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Joe Ricard |
Jan 24 2006, 10:20 AM
Dual valve spring?
majkos |
Jan 24 2006, 02:32 PM
Senior Member Group: Members Posts: 1,370 Joined: 29-February 04 From: Mile High 914 Member No.: 1,729 Region Association: Rocky Mountains |
Rick?
I see you can weld alumimum. What's your desirable amps setting? I wanna do alum. but know nothing. I'v a nice welder with argon, but the machine rated 50 amps, and this house has only 60! Kinda guessing I shouldn't need too much,for the fact,alum. has low melting point. |
fiid |
Jan 24 2006, 02:48 PM
Looks good - dig the pictures. Like Tom says - keep up the good fight.
I was wondering also if you'd considered getting some headers on there?? (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
McMark |
Jan 24 2006, 03:19 PM
Rick! Nice work. It looks familiar. I lave 928 engines! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Majkos, Aluminum takes a AC capable TIG to weld well. It takes lots more amperage because AL dissipates heat so well. Visit a local welding shop to pick up some scrap AL to practice on. Most hardware store AL is anodized which makes it almost impossible to weld successfully. |
Tom Perso |
Jan 24 2006, 04:04 PM
Crazy from the Cold... Group: Members Posts: 647 Joined: 8-August 03 From: Kalamazoo, MI Member No.: 1,003 |
Man Rick, that motor looks to be in good shape.
I remember that piece of metal that got stuck in the pump. It all makes sense now. Amazing it made it's way all the way down to the sump and back up the pickup tube. Nice work (IMG:http://www.914world.com/bbs2/html/emoticons/clap56.gif) Tom |
rick 918-S |
Jan 24 2006, 04:50 PM
Yep, stay tuned. (IMG:http://www.914world.com/bbs2/html/emoticons/wavey.gif) |
Lo-Fi Version | Time is now: 23rd November 2024 - 04:54 PM |
