20 Pages V « < 7 8 9 10 > »
> Starting a 1973 restoration, Restoring a left for dead $500 914...
jimkelly
post Dec 29 2008, 08:41 AM
Post #157
Delaware USA
is this NOT a classic thread ??
jim
FourBlades
post Jan 11 2009, 01:07 PM
Post #158
From Wreck to Rockin
Finishing the passenger side fender today. Welded on a patch.
Ground it down.
Just some little stuff left...
John
pktzygt
post Jan 11 2009, 01:23 PM
Post #159
Very impressive. Just this morning I was getting welder buying advice from a welder in the shipyard I am stationed at. I think I'll start with the rear trunk floor. I hope someday not to be afraid of doing work like the stuff you are doing.
FourBlades
post Jan 11 2009, 08:02 PM
Post #160
I started welding up the holes for the sail panel trim. Wire wheeling revealed
some rust issues once the paint came off. Doesn't look too bad from the outside,
just a few little holes:
Open it up and see why people say 914s rust from the inside out.
Cleaned it up, not too bad. I'll have to fix this another day. This area seems
designed to trap dirt and water thrown up by the rear wheels and cause rust.
Porsche could have designed a better way to seal up this area. The foam they
sprayed in here was where the rust was the worst.
There always seems to be just one more rust hole...
John
FourBlades
post Jan 18 2009, 04:15 PM
Post #161
Had a few minutes today to weld up the passenger sail.
Still needs another small patch.
John
FourBlades
post Feb 3 2009, 05:32 PM
Post #162
The cleanup continues. Ground the passenger sail panel.
Seam sealed the engine bay and passenger area. I really globbed the sealer on.
The so called brushable sealer is really a pain to put on neatly.
FourBlades
post Feb 3 2009, 05:37 PM
Post #163
Fitted the really nice door I got from SMG914. Thanks man, I wish you had a
passenger door to match it. (IMG:style_emoticons/default/biggrin.gif) I am going to have to weld a bunch of holes
in the skin of my passenger door.
Removed all the last bits of trim to get ready for painting!!! Gonna have some
time off work here soon and I want to get this thing painted.
I have a buncha questions about painting I will post in a different thread.
John
AgPete139
post Feb 4 2009, 11:36 PM
Post #164
AgPete139
Wow, and wow. Projects like these inspire me...nice job, man. (IMG:style_emoticons/default/pray.gif) You'll have patience with the rusting. Wow. Keep it up!
Pete
FourBlades
post Feb 6 2009, 05:08 PM
Post #165
Spent 6 hours today fixing my passenger door. I sand blasted the inside as much
as I could to remove all the rust. There were 5 areas which had rusted through.
The PO thoughtfully fixed this hole by putting on a layer of plastic tape and then
painting over it. (IMG:style_emoticons/default/mad.gif)
Any newbie knows you need at least 2 layers of tape for it to be considered a
permanent repair. (IMG:style_emoticons/default/laugh.gif)
Remember this when you are inspecting that newly painted car that is for sale.
This atrocity was actually pretty well hidden unless you looked for it.
I hope it does not hurt the "originality" of the car by not repairing it again with
tape, but I thought maybe metal would be better.
Using tape behind the patch helps hold it flush. This works better than taping
on the top of the patch because the mig wire just pushes the patch off the tape
that way. Welded and ground it down.
Fixing some other holes.
Ground them.
I was using an air gun to cool the welds as I went, but I must have overheated
the door skin because I ended up warping it nicely. There are a couple high
spots and one big oil canned spot. I tried shrinking it with a propane torch and
wet rag but it did not help much.
So how do I shrink these spots?
John
rjames
post Feb 6 2009, 07:04 PM
Post #166
I'm made of metal
Metal shinking disc? At least I've seen it done that way in other restos.
Just found a link: Linky
One question, which will undoubtedly show my ignorance- What dictates when seam sealer should be used?
sean_v8_914
post Feb 7 2009, 11:52 AM
Post #167
Chingon 601
that link just cost me an hour (IMG:style_emoticons/default/wink.gif)
FourBlades
post Feb 7 2009, 05:32 PM
Post #168
Those shrinking disks scare me. I have heard of them exploding and cutting
people up badly. Maybe that is just me being paranoid.
I tried using acetylene and managed to remove the oil canning (think pressing in
on the metal and it snapping back out) but could not completely flatten it. This
is partly because you can't get to the back of the panel due to the door beams
but mostly due to the fact that I don't know what I am doing.
Seam sealer: I believe you use it on all welded seams except the outside skin
of the car. The layers of the paint job should protect these seams from water.
John
jc914
post Feb 7 2009, 06:11 PM
Post #169
(IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/popcorn[1].gif) I keep on looking at your post once again amazing work
FourBlades
post Feb 8 2009, 04:43 PM
Post #170
Passenger tail light opening was horribly rusted. I cut it out and made a
replacement piece. This took a hour or so to make using the flimsy little
brake I have.
Clamped a piece of flattened, copper pipe behind the seam. I really tried to
weld slowly to avoid warping this thin sheet metal.
Put on a few tacks, stop, take a picture, wait a while.
Keep on until it is fully welded.
Slowly welded the rest. Using a copper backer makes a really big difference.
I like to use a lot of clamps to also take up some of the heat.
Test fit the tail light. I needed to do some trimming and hammering to make
it fit like this.
Painted and ready to rust out all over again.
John
MDG
post Feb 8 2009, 04:49 PM
Post #171
Wolf in wolf's clothing.
"Painted and ready to rust out all over again."
if it does, with your skills the rust won't stand a chance. This project is an inspiration - fantastic stuff man!
mike
FourBlades
post Feb 11 2009, 09:16 PM
Post #172
You call this a rust spot??? Pfffftttt!
I guess I have to fix it...
All welded and grounded up. Checking the tail light fit.
Wow, the tail lights and trunk lid still fit.
Now working on stripping the old paint and troweling on the bondo.
If you are using crumpled up newspaper to fill in a dent, does it matter if you
are using those shiny ad inserts or is only regular news print considered a
concours repair? (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/rolleyes.gif)
Ha ha, ok, so that was a joke, I know you should only use Road and Track
magazines.
John
MDG
post Feb 11 2009, 09:58 PM
Post #173
not only does your work continue to amaze . . .
it appears you've trained your car to levitate (IMG:style_emoticons/default/blink.gif)
huh, could this be the end of jackstands!?!
FourBlades
post Feb 12 2009, 08:54 AM
Post #174
Ha ha, Michael, actually it looks high because I got it sitting on 22s. (IMG:style_emoticons/default/av-943.gif)
How has TO been this winter? I love Ontario but its a little too cold for me...
John
MDG
post Feb 12 2009, 09:55 AM
Post #175
QUOTE(FourBlades @ Feb 12 2009, 09:54 AM) *
John
hey John, had a ton of snow in January - more than usual for this area. Now it's typical February slop; mid 40's - rain/snow/rain . . . it's one big puddle - at least it'll help wash away some of the salt (IMG:style_emoticons/default/dry.gif)
my dad is down in Naples - lucky bastard.
your car is coming together great!
m.
carr914
post Feb 12 2009, 10:19 AM
Post #176
Racer from Birth
QUOTE(FourBlades @ Feb 3 2009, 06:37 PM) *
John
That's because I beat you to the passenger door. It's on my Six. So we have another connection. (IMG:style_emoticons/default/biggrin.gif)
T.C.
you can just see the Tangerine door in my Signal Orange car in this pic
- Lo-Fi Version Time is now: 29th December 2024 - 01:25 AM
