Fuel Pump, Webers |
Fuel Pump, Webers |
southernmost914 |
Oct 24 2008, 05:25 PM
KEY WEST/HAVANA Tunnel Authority Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States |
[quote name='Elliot Cannon' date='Oct 24 2008, 06:46 PM' post='1094600']
[quote name='Todd Enlund' date='Oct 24 2008, 12:59 PM' post='1094538'] [quote name='Elliot Cannon' post='1094533' date='Oct 24 2008, 11:54 AM'] You can't PULL a liquid! [/quote] Yeah, but if the pump is lower than the tank, it could still be located in the engine bay... fuel would run to the engine bay even without a pump (IMG:style_emoticons/default/biggrin.gif) That's exactly my point. If the pump is lower than the tank, the static pressure to the pump is the same, weather the pump is in the front or the back. [/quote] (IMG:style_emoticons/default/agree.gif) This is getting deep. Ok, yes static pressure is the same front or back depending on the height the pump is mounted . The fuel line is a restiction to flow. The longer the line from the tank to the pump the more restriction to flow from the tank to the pump. The harder the pump will have to work for the same difference in pressure. It's only a pair of 44 webers. (IMG:style_emoticons/default/biggrin.gif) Steve |
PeeGreen 914 |
Oct 24 2008, 05:34 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
So I need a new pump and am going to locate it to the front. Is the CB good for my six and what regulator did you guys use?
Yes Todd... I am hijacking your thread... kinda (IMG:style_emoticons/default/laugh.gif) |
Mark Henry |
Oct 24 2008, 05:42 PM
For me it depends on the HP, faucet, CB are OK till about 140- 150hp, after that they will lean out your engine bad as they can't keep up.
After 150HP I use a Holley pump and regulator. BTW The little silver round pressure regulators are pure junk. |
zx-niner |
Oct 25 2008, 12:23 AM
Member Group: Members Posts: 294 Joined: 13-June 05 From: Las Vegas, NV Member No.: 4,269 Region Association: Central California |
PeeGreen 914 |
Oct 25 2008, 12:40 AM
Oh geez.... this again (IMG:style_emoticons/default/av-943.gif) There was a big thread about this about six months ago or a year ago. |
rhodyguy |
Oct 26 2008, 01:43 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
why the big rush to relocate the pumps to the front? the cb will mount nicely to the rear of the lower firewall. you'll either have to figure a way to splice into the stock wiring at the rear so you can use the relay and fuse or run to a keyed terminal off the interior fuse panel. carry fuses with the later.
k |
Elliot Cannon |
Oct 26 2008, 02:00 PM
You lower the pressure in the straw and the liquid is "pushed" through by outside air pressure. It was all explained to me when I bought the manual that also included this explanation for how them airplane things fly. Attached image(s) |
ericread |
Oct 26 2008, 02:07 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
You lower the pressure in the straw and the liquid is "pushed" through by outside air pressure. It was all explained to me when I bought the manual that also included this explanation for how them airplane things fly. (IMG:style_emoticons/default/lol3.gif) Great post - I wondered how an airplane gets airborne!!! Eric |
Mikey914 |
Oct 26 2008, 04:31 PM
The rubber man Group: Members Posts: 12,711 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
As an airline pilot I can summarize how aircraft fly .....PFM
Pure F'n magic But seriously, it should work either way, just lie a hydraulic pump, which basically it is. |
Lo-Fi Version | Time is now: 27th September 2024 - 01:58 PM |
