What oil temp Temperature gauge do I trust, Just installed the new Pressure & CHT guages |
jc914 |
Nov 19 2008, 11:38 PM
Member Group: Members Posts: 289 Joined: 15-September 08 From: Miami, Florida Member No.: 9,548 Region Association: South East States |
How important is to have an oil pressure gauge.
southernmost914 |
Nov 20 2008, 02:06 PM
KEY WEST/HAVANA Tunnel Authority Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States |
How important is to have an oil pressure gauge. IMHO the most important. You really need oil pressure, oil temperature and CHT to monitor your engine. Better yet 4 CHTs (IMG:style_emoticons/default/w00t.gif) Steve |
jc914 |
Nov 20 2008, 03:00 PM
Thanks steve I am going to get Oil pressure and a cht. as for the oil pressure which sender do I get. look at the link below I want a dual sender for the light and the gauge. The differnce is a floating ground or a standard ground. which one do i get.
http://egauges.com/vdo_send.asp?Sender=80PSI_5Bar_VDO Also Steve you have an A/C like I do in the car where did you place the extra 2 gauges in the dash. Once again Thank YOU JC |
southernmost914 |
Nov 20 2008, 03:47 PM
sending unit 360-900 , and I have no stock gauges in the console.
Steve |
southernmost914 |
Nov 20 2008, 03:52 PM
Sending unit well grounded ( I swear that is not teflon tape on those fittings)with high pressure hose, grease gun or aeroquip hose.
Steve |
jc914 |
Nov 20 2008, 04:29 PM
THANKS SO MUCH STEVE thats exactly the information I needed
JC |
marks914 |
Nov 20 2008, 05:24 PM
Senior Member Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
Thanks steve I am going to get Oil pressure and a cht. as for the oil pressure which sender do I get. look at the link below I want a dual sender for the light and the gauge. The differnce is a floating ground or a standard ground. which one do i get. http://egauges.com/vdo_send.asp?Sender=80PSI_5Bar_VDO Also Steve you have an A/C like I do in the car where did you place the extra 2 gauges in the dash. Once again Thank YOU JC Put them in a quad gauge, no holes anywhere! Even put a CHT in there Mark (IMG:http://inlinethumb47.webshots.com/40622/2103925250057582025S500x500Q85.jpg) |
southernmost914 |
Nov 20 2008, 06:04 PM
(IMG:style_emoticons/default/agree.gif) That gauge is a work of art. In a South Florida climate having to compansate for ambient temperatures would drive me crazy. I'm all about marketing but I think JC is on a $$$$$$ controlled cost plan.
Steve |
jc914 |
Nov 20 2008, 08:01 PM
Those Gauges are really really nice If i had the money i would buy but right now i am totally on a budget.
KaptKaos |
Nov 20 2008, 11:50 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
I just put one of these gauges in my car tonight.
Anyone have experience with these compared to the dipstick gauge? (note: the one I put in was in better shape, this is the spare (IMG:style_emoticons/default/laugh.gif) ) |
KaptKaos |
Nov 22 2008, 12:26 AM
jc914 |
Nov 22 2008, 08:02 AM
I have not but here is a bump hope some one can answer you.
jc914 |
marks914 |
Nov 22 2008, 09:17 AM
300 deg is at the beginning of the red. Make sure you have the right sender, which I think is NLA.
Mark |
KaptKaos |
Nov 22 2008, 01:07 PM
300 deg is at the beginning of the red. Make sure you have the right sender, which I think is NLA. Mark I think I bought it from Pelican some time ago (over 2 years). It doesn't look like the one on their site now. It has a longer "sensor" than the one on their site. I have a sender form another motor that looks like the new one I just installed. I guess we'll see when I finish wiring it up. (IMG:style_emoticons/default/biggrin.gif) |
marks914 |
Nov 22 2008, 01:14 PM
300 deg is at the beginning of the red. Make sure you have the right sender, which I think is NLA. Mark I think I bought it from Pelican some time ago (over 2 years). It doesn't look like the one on their site now. It has a longer "sensor" than the one on their site. I have a sender form another motor that looks like the new one I just installed. I guess we'll see when I finish wiring it up. (IMG:style_emoticons/default/biggrin.gif) TRhere should be some numbers on the sender, that should tell you what yo have Mark |
jc914 |
Nov 23 2008, 05:12 PM
I was re in stalling my Sway bar "rear ball links (what a pain) but did it. So went looking about underneath the car i found this. It is located above the heat exchangers. does this affect the cooling of the oil. (WHAT is this part for)
(IMG:http://i176.photobucket.com/albums/w177/JCD404/IMG_2939.jpg) |
Gint |
Nov 23 2008, 07:38 PM
Mike Ginter Group: Admin Posts: 16,093 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
That boot is the cooling vent for the alternator. If it's off, you'll lose some cooling air flow from the rest of the system, so in theory it would affect your oil temps. But I doubt it would be by much. I can't quite tell from that pic, but if it's disconnected you should loosen that clamp and put it back on.
jc914 |
Nov 24 2008, 06:14 PM
yes it is disconnected i tried to push it in but i was not able to. I really donot want to remove the heat exchanger.
jc914 |
Nov 24 2008, 08:48 PM
Does any one knows if this really affects the oil cooling. look two posts up.
Lo-Fi Version | Time is now: 27th September 2024 - 12:06 PM |
