2 Pages V < 1 2
> Guage lighting update for the CSOB, Electro Luminescent illumination for your guages!
Rotary'14
post Sep 15 2010, 07:01 PM
Post #21
QUOTE(StratPlayer @ Sep 15 2010, 05:39 PM) *
I had a chance to show how well this set up works at the RRC in moab last weekend. The folks that saw my gauges were impressed and I explained how easy it was to do this to the gauges. Great Idea, Works Great..... (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif)
I saw a guy on the bird board selling these kits for the 911 guys and they were all over his kit at $90. I wish I advertised better. BTW the 911 guys pics of his gauges were really good.
-Robert
Al Meredith
post Sep 15 2010, 07:11 PM
Post #22
I just completed a similer installation with some Fiberoptic / LED cable. I did it on my 912E . The guages on the 70's 911's are not bright enough to see and need something to improve the visability . I'm also working with a green LED that I bought at PEP BOYS to use in the green arrows, can't see them in the daylight.
Mark Henry
post Sep 16 2010, 07:11 AM
Post #23
that's what I do!
Cool stuff!
Are these still dim-able or just on/off?
(I think I know, but just in case someone asks.)
charliew
post Sep 16 2010, 07:57 AM
Post #24
At night can the gauge lights be turned up brighter than necessary or is the maximum still just barely enough? I know this might be a relative question but I would like to make it brighter than necessary then be able to adjust it down to the desired level. Also I still like the bling of the aftermarket gauges that have changeable colors. Has anyone seen a supplier that has a multicolored strip?
Als914
post Sep 16 2010, 10:32 AM
Post #25
Lighting my way
QUOTE(charliew @ Sep 16 2010, 06:57 AM) *
I modified my set with mutiple LED colors
Attached Image These are in my '74 and pritty much how they look at night
Attached Image Anothr set I did in cool white.
Attached Image And another.
charliew
post Sep 16 2010, 10:36 AM
Post #26
In gauges I like bling, that looks good in my opinion. Is that led bulb strips or the wire strips connected together?
Als914
post Sep 16 2010, 10:57 AM
Post #27
Lighting my way
QUOTE(charliew @ Sep 16 2010, 09:36 AM) *
The above gauges were all done with LED, flexible strips. The multiple color gauges (top pic) were splice and soldered (IMG:style_emoticons/default/welder.gif) not easily done and very time consuming.
Rotary'14
post Sep 16 2010, 11:05 AM
Post #28
I would think that a few different colored EL wires can be routed behind the bezel and a simple multi-gate switch would be used to switch between them,, then you can have white,, blue,, green,, I would think 3 selectable colors would be cool. In fact if you hook up an RPM switch you can change the gauge colors orange, red when you get near red line like a shift light. (but you can only tell at nite) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/idea.gif)
-Robert
2 Pages V < 1 2
24 User(s) are reading this topic (24 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 23rd November 2024 - 03:07 PM
