Air foils under car infront of engine., engine cooling |
Geezer914 |
Aug 24 2009, 08:08 AM
Geezer914 Group: Members Posts: 1,656 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
There is a set for sale on ebay
Gint |
Aug 24 2009, 08:23 AM
Mike Ginter Group: Admin Posts: 16,093 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
If all you want is the functionality it would be easy to make a set from something other than plastic.
RohJay |
Aug 24 2009, 12:22 PM
Member Group: Members Posts: 189 Joined: 24-April 07 From: Colombo, SRI LANKA Member No.: 7,689 |
There is a set for sale on ebay Can we have the link please? QUOTE If all you want is the functionality it would be easy to make a set from something other than plastic. Aluminium perhaps? Will go that way if I cant find a set. Would appreciate if someone would provide dimensions... |
Shade Tree |
Aug 24 2009, 02:18 PM
Member Group: Members Posts: 260 Joined: 18-December 08 From: Springfield, Oregon Member No.: 9,860 Region Association: Pacific Northwest |
My head temp went down almost 20 degrees on the freeway after adding these.
SLITS |
Aug 24 2009, 02:26 PM
You would have to put some kind of hinge and return spring if made out of aluminum. They were made to be flexible for a very obvious reason.
They are installed 385mm apart (15.5") to the tip of the wide bottom part or 7 3/4" from the centerline of the car. |
Mikey914 |
Aug 25 2009, 12:36 AM
The rubber man Group: Members Posts: 12,711 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Why not make these out of plastic? It wouldn't be too hard to extrude a profile similar (but slightly thicker). As these Have the XXX on the back of them to add reinforcement. If there's enough interest I could do these. I'ld guess about $15 a set. As far as aluminum, I could do that pretty easily on the brake, but I think it'ld get boogered up, and If you back over something it would be less forgiving than the plastic.
Gint |
Aug 25 2009, 08:09 AM
No good reason not to make them out of plastic... if you can extrude a similar profile in plastic. (IMG:style_emoticons/default/wink.gif) Most of us don't have that ability in our garages. Sounds like a new product opportunity Mark!
jaxdream |
Aug 25 2009, 08:13 AM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
Would it make a difference if the air foil went all the way across the bottom , or would this hurt more than help ?? Just curious since the idea of the foil is to create a low preasure area under the engine to help scavenge the air coming in from the top through the fan blowing over the cylinders ??.....Just a thought (IMG:style_emoticons/default/confused24.gif)
Jaxdream |
SLITS |
Aug 25 2009, 08:33 AM
Just looking at the design I would say there is a reason they do not go all the way across. Besides the flaps creating a lo pressure area beneath the cylinders, that gap between them is a "venturi" so to speak, increases the speed air moving through creating it's own "suction" to draw away expelled hot air to the center line of the car.
Hey, after two cups of coffee I can come up with all sorts of things. |
jaxdream |
Aug 25 2009, 08:58 AM
I'm just working on my second cup . Ok , the venturi effect , wouldn't it increase the velocity of the air moving underneath ?? when the idea was to create a lower preasure area , or was it just for the ,let's say alleys of air in the general vicinity of the two paths ??
Jaxdream |
SLITS |
Aug 25 2009, 02:51 PM
Lo pressure behind the flaps ... higher speed air thru the center would also create a suction effect on the pool of hot air behind the flaps to take the hot air away.
Next! |
Mikey914 |
Aug 25 2009, 03:46 PM
If I extrude the same profile, we could play with how they're cut, but my first thought is to make it pretty close to the same shape, they spent a bunch of effort to make these the way they did. I know that they were a molded part instead of extruded, they may have done this as it was cheaper for them in large quantity. I know there was someone that was modeling aerodynamics for the 914, I would be curious to see if this was addressed, I know there was allot of conversation about tails, and some body effects. Anyone remember who that was?
I f there is enough interest and I do make these, it would be nice to see if we could tweak it to make it even more efficient. and slits is correct the air has to move faster to get over the top creating a low pressure behind (venturi effect). |
montoya 73 2.0 |
Aug 25 2009, 03:54 PM
Lack of consideration to others, and Selfish! Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
Sounds like we need some wind tunnel testing.
DNHunt |
Aug 26 2009, 07:35 AM
QUOTE Sounds like we need some wind tunnel testing. Ron might volunteer for that task too. A can of beans and him in a garage should work. (IMG:style_emoticons/default/lol-2.gif) Dave |
KELTY360 |
Aug 26 2009, 08:54 AM
914 Neferati Group: Members Posts: 5,081 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
QUOTE Sounds like we need some wind tunnel testing. Ron might volunteer for that task too. A can of beans and him in a garage should work. (IMG:style_emoticons/default/lol-2.gif) Dave (IMG:style_emoticons/default/chairfall.gif) (IMG:style_emoticons/default/av-943.gif) Might be tough to turn that 'wind' off once it gets going. Better have an exit strategy. (IMG:style_emoticons/default/icon8.gif) |
Sleepin |
Aug 26 2009, 09:06 AM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
No good reason not to make them out of plastic... if you can extrude a similar profile in plastic. (IMG:style_emoticons/default/wink.gif) Most of us don't have that ability in our garages. Sounds like a new product opportunity Mark! Soon there will not be anything that Mark does not make for a 914! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/aktion035.gif) Yeah, watch out for Ron's windtunnel...keep away from an open flame! (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/av-943.gif) |
jaxdream |
Aug 26 2009, 09:19 AM
QUOTE Sounds like we need some wind tunnel testing. Ron might volunteer for that task too. A can of beans and him in a garage should work. (IMG:style_emoticons/default/lol-2.gif) Dave (IMG:style_emoticons/default/chairfall.gif) (IMG:style_emoticons/default/av-943.gif) Might be tough to turn that 'wind' off once it gets going. Better have an exit strategy. (IMG:style_emoticons/default/icon8.gif) Shouldn't that be an exhaust strategy ?? Jaxdream |
blitZ |
Aug 26 2009, 09:24 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
Couldn't you use a diffuser method to achieve the same result?
Ferg |
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
I made a set from AL duct stuff from the hardware store and tin snips, easy as pie, only downside was they were sharp! Cut myself twice on them while under the car.
Ferg |
Lo-Fi Version | Time is now: 26th September 2024 - 09:56 PM |
