Sure no prob. I have learned that no matter how cheap you think it will be ...it will always fall into line with most other options.
The car was $600. It was mechanically great but cosmetically not so good. I was able to drive it home which was a plus. Most important thing is to listen and observe the engine...when you start it, it should idle about 1500 or so, then settle to a very even idle of 800ish. Watch the temp and look under it for leaks. You should be able to tell if it's strong or not. Expect to change the seals unless you get lucky like BIGKAT and find one that is practically new. These leak oil just like 911 engines after a while.
At this point the stuff has totaled:
Car - $600
WRX Trans and flywheel - $800
coldwaterconversions stuff (everything but the hard engine mounts) $1375
Custom exhaust and related goodies, plus another mount - $350
Engine seals, timing belt, spark plugs, etc ~$400ish
1990-1992
Honda Accord shifter - $40 shipped
Still need radiator hoses, cable shift linkage, cables, some CV joints, a clutch disc, slave cylinder, etc. Probably another $800 or so.
Keep in mind that you can part out the SVX and recoup some costs. All of the small stuff can be sold (switches, controls, mirrors, interior stuff, lenses). The differentials, axles/cv's and most importantly a good trans are worth $. Also the leather interiors are very desirable. SVXWorld.com is a good place to sell stuff. Just wait til I am done
![biggrin.gif](http://www.914world.com/bbs2/style_emoticons/default/biggrin.gif)
(Kidding, it doesn't matter there are several part-outs on there now). A metal scrapper paid $150 for the shell. I'll sell my current TIV engine, side shift trans, linkage, etc. (hey side shift conversion people!)and should be looking pretty good. I will also do a 5 lug conversion. Already bought the wheels. Got a great line on the rest as well... I figure the net will be $6k ish...so let's call it $12k.
The cool thing about the SVX is it's very powerful in stock form so you can use most of the stock components as well as the niceties like air cond, real heater, etc. You can also use the fuel pump which makes it convenient. And they are pretty cheap. They are
extremely similar to 914's. Manufactured roughly the same number of years, quirky but cool, a little too expensive when new, all years are identical shells with small cosmetic revisions each year. They are in the same place 914's were in the late '90's...lots of part-outs, not a lot of love, small following of fanatics... weird....
