Full Version: First 914 build... V8 twin turbo SBC
Pages: 1, 2, 3
beam944
Hi everyone...I am new to the 914 world although not new to Porsche's. I have owned 3 944's and actually loved every one of them. I came across a craigslist ad for a v8 914 and well.....here it goes.. wish me luck ...any and all input is appreciated.
This engine is just set in place as mock up only...thats actually a 1966 283 out of a ChevyII
I dont know why this radiator is where its at...going to get a race aluminum in the front
lots of work to do here..
will have lots of parts to sale off of this project
definitely going to need some more space for 12 inch wide tires..so probably won't look like this when i'm done
andys
Your first challenge will be to find a suitable transaxle capable of withstanding twin turbo power.
Andys
2mAn
I honestly think you should start by getting it going with just the SBC and then plan the twin turbo if it isnt scary enough.
I love 944s and would love to put a LS motor in that instead!
beam944
I have my photos of the car up on photobucket but cant seem to get them here...i am new to posting on forums any help would be great....and yes transaxle will be an issue i agree...but then again i am looking to do a retro look and not really high hp...400-500 hp is the absolute most i want ... well....
beam944
i agree totally
beam944
The beginning...
2mAn
QUOTE(beam944 @ Apr 15 2014, 02:14 PM) *
when you have the image up on photobucket there should be a list on the right that has says "link to share" click on the IMG link and paste (CTRL-V) on reply and voila pictures!
beam944
Thanks!
beam944
IPB Image
beam944
Thanks alot 2mAn! so this is much easier now..
IPB Image
IPB Image
IPB Image
IPB Image
IPB Image
IPB Image
IPB Image
76-914
2mAn
QUOTE(beam944 @ Apr 15 2014, 02:30 PM) *
honestly, sell the turbo manifolds use that money either towards the renegade radiator setup (I think its around 750-1000). the next thing would be to properly mount the transmission, that chain link looks wacko.gif
beam944
I know you say ditch the turbos...but i cant get the thought out of my head...lol ... yes the chain has got to go...this is how i got it...needless to say alot of work to be done. I am going for era correct age on everything as if someone in 1974 did a v8 conversion.
dlee6204
I saw that car on Craigslist. I almost made a move when it first popped up. Should be a good project.
beam944
I have looked at v8 conversions before and no how much they can be...for the price I had too...but it does need a lot of work
bulitt
QUOTE(dlee6204 @ Apr 15 2014, 05:57 PM) *
Saw it also 1200$
And V8 conversions started in the early 70's
FourBlades
Post a lot of pictures as you go.
Getting it running would make it more fun while you plan your next step.
Too many of these turn into 3 years on jack stands before turning a wheel.
John
beam944
Next week starts the build... Have to finish a little Jackson supercharged Honda first...lol
Elliot Cannon
400 to 500 horse power??!! That transmission won't last unless you really baby it. But how much fun would that be. laugh.gif
messix
tony is running 400+ in his with a 901 for the past 5+ years and he doesn't "baby it" but he doesn't punish it either.
Mike Bellis
The 283 is a good platform. You will have around 250hp (mine did) without the turbos. Your 400hp mark is easy to reach. The motor looks like it sits too far back in the chassis. Most V8 conversions sit 1.5" back. This can be measured from the rear tranny mounts. You end up with around 1/2" clearance at the valve cover/firewall. Moving the engine more forward will help with chassis balance. Then you can flip flop the exhaust manifolds to get the turbos away from the rear window.
beam944
The 283 would have to be rebuilt, and I would love to build it but for time constraints I have a 350 already built ready to go... Yes the engine is to far back and needs to be moved forward...the guy I purchased it from had it in just for mock up...and from the angle of the axles it is about 3 inches too far back...it is also way high
Dave_Darling
It'll be fun, but you will get an education in the weak spots in the drive train. One piece at a time. You'll break something, replace it with a stronger part, and then the next weakest thing will break.
The times it runs will be scary fun, though!
--DD
beam944
I can't wait...fortunately I have a small background in chassis building...well I have the help of ppl that do it for a living, so there will definitely be parts made and technology incorporated into this build from NASCAR... I am foaming at the mouth to get started!
Andyrew
My suggestion if you want to try and keep the 901 trani.. Go with a SUPER big turbo/twin turbos.
This way you can keep the boost very low, and have the boost start to build pretty late (for a v8) like say 3k. This will keep the torque down and will help you not destroy your 901, not to mention keep the turbo's/oil nice and cool. You will have boost lag, but the feeling of it spooling and building boost will just be so much more fun.
beam944
I agree!! kind of like power band on a 2 stroke..
beam944
IPB Image
stainless goodies...
Andyrew
Better off going with a large rear mount turbo. Put the heat away from the engine bay.
RJMII
Maybe a gt 28r on each bank, or a td05 16g? That would keep your exhaust to intake pressure ratio pretty close to 1:1 and the power band up a little higher after a good spool up, and you wouldn't need a special turbo cam.
Andyrew
A pair of gt28's on 4.6L? First off I dont think he should go ball bearing turbo. The whole goal here isnt to make crazy power at low rpm, its to have a turbocharged sbc 914 in some package that wont destroy everything the first time he gets on boost...
I think a larger journal bearing single turbo would make good power, give him some spool time, and be much cheaper.
Heres an interesting article.
http://www.hotrod.com/techarticles/engine/...98/viewall.html
bulitt
Put the 350 into it and get it running. This is a 2300lb car and with 350hp you will have the power to weight ratio of a dodge Viper. Then if you still have a hankering for turbos have at it. But, this is the land of Nascar. People put speed equipment out in the recycling bins. biggrin.gif
3d914
Nah, 350hp is child's play. Go for the twin-turbo V8, 500hp, 400ft. lbs for 200mph +. (Of course you can't do that easily with the 901 tranny)
That'll wake up some of the big boys!
beam944
I am taking all of the suggestions in....I also like the designing aspect of this as well..here are some theoretical numbers I came up with let me know what you thinkIPB Image
IPB Image
IPB Image
drive-ability
That car's going to be a handfull. Buckle up and hang on ! biggrin.gif Did I see a radiator or intercooler in the back ? I'm sure it would work fine, when ya turbo the space gets taken up quick and the temps go up as well. Turbo engines are so fantastic when their setup right, but they scare me in a fun way.
Andyrew
QUOTE(beam944 @ Apr 19 2014, 09:01 PM) *
IPB Image
IPB Image
Maybe at 7lbs of boost with little tuning.... That calculator seriously underestimates what a turbo can do... My 1.8L Audi engine makes that much power with a turbo much smaller than were talking... Seriously...
You put a nice big turbo on it and you'll make whatever the bottom end can hold... Its all about moving the power curve where you want it... Thats where sizing will come in. 350lbs tq at 2krpm is really plenty on the street, Where you actually will want that turbo is to start spooling ~3500 and then build the engine to allow you to rev to 7-8k (You've got nascar stuff... right?) so that you can rev it out and make some power (if you want...)...
Traction will be the real issue when your getting to that much power... Much above 400hp its starts getting to be a real problem keeping the car straight. I've ridden in a 550hp v8 914 with maaaasive hoosier slicks, We stayed sideways till 100....
bulitt
Don't mess around with the SBC. Put a twin turbo Viper V10 in there. 1200hp The extra weight will help with your traction issues.
Underground Racing
beam944
Does anyone know if there has been traction control incorporated into a 914 conversion? smile.gif
Mike Bellis
QUOTE(beam944 @ Apr 20 2014, 07:07 AM) *
It was an option for me when I did my conversion. I opted not to incorporate since it was designed around a 3500lb car. When it came down to it. I only grafted in the steering column and dash cluster.
Bosch makes a universal version you can add and program. It only costs several thousand dollars. Many race teams use the system.
beam944
Of course I will have to drive it without it and see if it would be worthy of the cost to do...reason for such low numbers on the engine design as well...definitely more horses stored in that little 283 but I also want reliability... not saying we have used TC in racing...cough , cough....but there is some laying around that could be tried out...I'm a ways from that point but hope to be starting on this project end of week.
Andyrew
You probably have much better access to traction control systems than the rest of us. Without using something designed for a specific engine/ecu its really difficult to design a system...
Traction control would be nice....
beam944
Finished the little supercharged civic...
IPB Image
Dyno time...any guesser's?
IPB Image
Dyno tomorrow and then i can focus on the 914!!
Andyrew
Well a nicely built d16z6 makes ~ 145crank , If your dyno'ing to the wheels lets say 170-180whp. And thats pretty generous. smile.gif What supercharger and boost?
veekry9
beam944
Hi there.
You're gonna need a bigger tire..
Drysump-pan,alloy heads if you can,and with a mild build that 350 can be a cheep
way to frightening performance.
More power=more strength=more$$=more fun.
I even like the color.
beam944
This is the d16a VTEC... With Jackson supercharger with 6lbs of boost SPEC stage 3 clutch and aluminum flywheel
Andyrew
Yes, the D16 vtech engine is either the D16Z6 or D16Y8. Then again the stock engine in that car is a D16A6, it could just have a head swap to use the Z6/Y8 head.
Dave_Darling
VTEC, Andrew. VTECH is a crappy phone.
Oh, and putting a Z6 or Y8 (and there are a couple others that work) head on a non-VTEC bottom end is called a "Mini-Me" swap. Originally it was "Mini-Me LS-VTEC", but got shortened.
--DD
beam944
Ran late today...but i did get it on the dyno strapped down and ready to see what it has in the morning... i'm going to guess 185/170... this dyno is very cruel
IPB Image
beam944
Also thinking ahead a little bit... thinking about making my own 8 into one headers for the 914 build and incorporate one turbo like someone suggested ... i think it will achieve the sound i'm looking for and compliment the high revs of the 283.... thoughts?
Andyrew
QUOTE(Dave_Darling @ Apr 21 2014, 03:31 PM) *
Mike Bellis
QUOTE(beam944 @ Apr 21 2014, 04:51 PM) *
I like the 8 into 1 turbo idea. The short stroke on the 283 can spin guick if built right.
Invision Power Board © 2001-2024 Invision Power Services, Inc.
