Left & right rear floor pans from Restoration Design. This started out as part# P345 from the RD catalog. I cut out the center tunnel for my project, so the inner flanges were cut off. These would be a very economical fix for a car only rusted in the outer pan areas, or a new flange could be welded on. $25 each:
Battery hold down clamp from RD, new $4:
OEM Bumper guards for 1974 car with mounting hardware, $20 each:
OEM center wheel caps - $20/set:
Two partial ECU brackets - $5 each:
OEM firewall back pad - $10:
Three port fuel pump with mounting bracket. Leaks - core only - $5:
OEM jack post plug - $3:
MPS bracket - $5:
