QUOTE(GeorgeRud @ May 1 2014, 08:44 AM)
If you do end up gabbing some outer envelopes for the headers, please post pics as a lot of members would be interested in seeing how they're made. Only suggestion is that you not weld the outer envelope to the header as that is supposed to create a potential weak spot that can crack. There is a reason that all the factory and SSI heat exchangers are not welded.
In my experience they put in a couple of little tacks to maintain position. I do want heat, but having the headers perform properly is more important. On the '76 2056 I am running heat exchangers I fabbed the top ends for (where they go to the flapper boxes), so I had em completely disassembled. I used Eastwood high temp paint inside and a bit of fiberglass to keep them from rattling. After the paint cooked so far so good. But I also have a CO alarm from Walmart. Route 66 purchase.
Also - Thanks Marty. I am psyched. I expect grace in form. And also it is one more thing checked off.
