QUOTE(TargaToy @ Sep 15 2014, 06:38 PM)
Converting my 72 to side shift. I've got the bar but all the itty bitty mount parts went away with the donor car.
I'm looking for the top "plates" that allow the bar to hard mount to the car as well as any associated bolts, washers, nuts.
Thanks.
I have the plates. The bolts are 10 mm x 100 mm. I might have some used ones. Not to hard to find new. The small brackets attach to the body with 8 mm x 20mm bolts.
Do you have the two brackets that bolt to the engine and motor mounts?
