Full Version: Koni Rear Shock Leaking - Some Question?
seventythree
Hi,
I have a Koni Sport adjustable shock (yellow) that is somehow leaking.
There is a trace of shock oil running down the side that beads up on the bottom but doesn't drip.
Took off the shock, cleaned everything really well and actuated on the bench by hand. There is no sign of oil keaking from anywhere. Up and down action is smooth and provides uniform resistance. The gas charge is still there just like before, so when I push all the way down, the plunger extends itself pretty nicely.
Having said all of the above:
Where did the leak come from?
Why isn't it leaking on the bench?
If a seal is bad to allow oil to leak out, why is the gas still in there?
Or, are the gas and the oil contained in separate chambers (unlikely)?
TIA
JimN73
Konis have a lifetime warranty, if you have the receipt. You can submit a request online or call Koni North America.
They will 'sell' you a new shock, ship quickly and then return your $$ when the warranty request is approved. Or, you can send it back and wait for them to approve and send a new one.
Invision Power Board © 2001-2024 Invision Power Services, Inc.
