Very large stash of Porsche 914 parts, some extremely rare (a few select 911 parts too)
See the entire inventory (images and prices) here (cut and paste to your browser):
http://s32.photobucket.com/user/david16481...401894749848999
Located in Charles Town, WV (eastern panhandle) 25442
Don’t reply to this posting or PM me as this is for a friend of mine. I rarely use 914World anymore.
Contact Greg at
greg_cobb@comcast.net
914 Calipers=$75 a pair
911 Calipers=$125 pair
Accusump=$200
Front turn lens (euro?)= $40 pair
Axles/CV’s/Stubs=$125 each
Interior back panel (with light) =$100
Battery tray (new) =$40
Bilstien yellow=$125 pair
Front hoods=$175 each
Porsche 914 Bra=$75
New (German) rotors front and rear=$50 each
Cam=$50
A-Arms w/cross member=$200
A-Arms=$85 Each
CV’s=$45 each
Dash cover=$75
Engine lid w/rain tray=$125
Deep sumps=$50 each
Ignition rotor (new) =$30
Fog relay=$20
Square relay=$10
Ignition condensers=$18 each
Two GA 2.0 block w/cranks=$750 each
Various fan shrouds=$40 each
Fiberglass GT style fender flares=$150 a pair
Fuel pump=$50
GC 2.0 bare block (repairable crank journal damage, new studs) =$100
Headlight motors=$50 each
Rare headlight washer motor=$75
Heat exchangers (lightly used) =$200 set
Type IV heads=$200 set
Four 2.0 jugs=$125 full set
Koni yellow or koni red=$125 a set
License plate/trunk light=$30
Oil cooler=$35
Oil cooler with breather tank=$75
Rain tray=$50
Rear lenses=$75 each
Finned alum cylinder covers=$75 pair
Seat mounts=$35 each
Two solex carbs w/intakes=$500
Speaker cover=$75
Outer rocker (steel) =$125
Steering rack w/tie rods=$350
Transmission side shift console cover=$40
CV boots (new) =$5 each
Steering boots (new) =$15 each
Transmission linkage firewall boots (new) = $20 each
OEM air filters (new) = $12 each
OEM German oil filter=$15
Black powder coated engine tins=$400 set
Trailing arms (with shafts) =$100 each
Transmission cores=$300 each
Tall intakes=$150
Approximately 11k in parts.
Parts sold individually or the entire horde could be had for bids over 8k
