Thanks for the link. These will come in handy when I get the housing, which is what I'm looking for I've updated the title to make it clearer. Thanks again.
QUOTE(RazorbackFan78 @ Mar 25 2015, 10:41 AM)
Mike check this eBay listing. I picked up two of these last week. Not sure if this is what you're looking for.
Sorry for slight hi-jack of the thread. Quick question, so how did the filter fit ? Quality ok ?
Thanks
It was a perfect fit and in good condition. I had been to O'Reily's and they measured it but couldn't find a suitable replacement. I'd be curious to know the STP filter # mentioned at Autozone. Anyone know?
913B
Mar 28 2015, 03:19 PM
QUOTE(RazorbackFan78 @ Mar 28 2015, 06:52 AM)
QUOTE(porsche913b_sp @ Mar 28 2015, 12:08 AM)
QUOTE(RazorbackFan78 @ Mar 25 2015, 07:41 AM)
Thanks
I tried buying it online and it was no longer available. I have not tried going into a store.
stinkindiesel
Mar 31 2015, 04:02 PM
My local Autozone has told me the STP filter is NLA. I've been looking for a suitable replacement as well. From what I have, the OEM filter was a Mann C2180. 124mm ID 207mm OD 82mm tall
The AF103 is 125mm ID 205mm OD 82mm tall
Looks good if you can find one.
The K & N E-1040 160mm ID 211mm OD 83mm tall but I'm not a big fan of K & N.
Summit also shows a Motocraft C2OZ9601AR (FA3R) 3.225" tall (81.9mm) 8.313" OD (211.1mm) but can't find an ID for it. I also see slight variations on dimensions depending on where you look.
Just found this on Summit as well. Champion 70567 8.410" OD (213.6mm) 6.630" ID (168.4mm) 3.230" tall (82.0mm) Cheap, too! I'd need to take a quick look at the housing to make sure 8.4" would fit, but it should be close enough to the OEM 8.15" to work. If you think about it, that's only 0.13" closer to the outside of the housing. Couldn't make that much difference in air flow.
Gary
TheCabinetmaker
Apr 1 2015, 05:11 PM
Did you find a housing? I have a few.
mangrum
Apr 2 2015, 11:20 AM
No, I have not found a housing. Please send me pics, descriptions and prices. PM or mike_mangrum@yahoo.com.
QUOTE(The Cabinetmaker @ Apr 1 2015, 07:11 PM)
Mr.Nobody
Apr 25 2015, 10:57 AM
Quick questions, because this is right on track with what I'm looking for. Sorry to threadjack.
I want to replace the oil bath unit with a paper filter setup. What is the housing you guys are using? Where can it be found? Is it an OEM part or something aftermarket?
Got any pictures? Feel free to pm.
Thanks for the help.
TheCabinetmaker
Apr 25 2015, 12:18 PM
Pm sent, Mr nobody.
